Hi, I use Firefox to see my feeds, but the time stamp is too short and I can't read it completely. Can you suggest me some trick to see the complete string of time stamp? The file attached contains an example
thank-you in advance
Paolo
time stamp on viewing feed
- DJDevon3
Re: time stamp on viewing feed
Can confirm, happens in my Firefox too. Column should use relative position to display all text but seems to have fixed width. Or the time stamp is intentionally truncated with … which isn’t a good idea as time stamps might need to be verified to the second for whatever reason.
- brubell
- Learn User Page
Hi - thank you for reporting this issue. I'm able to reproduce the view from the screenshot and have filed a bug with the Adafruit IO development team. There is no ETA for when this will be fixed, however, this thread will be updated once we have patched and deployed a fix.
