time stamp on viewing feed
wemoslora
Post by wemoslora »
Hi, I use Firefox to see my feeds, but the time stamp is too short and I can't read it completely. Can you suggest me some trick to see the complete string of time stamp? The file attached contains an example
Feed view
Feed view
thank-you in advance
Paolo
DJDevon3
Re: time stamp on viewing feed
Post by DJDevon3 »
Can confirm, happens in my Firefox too. Column should use relative position to display all text but seems to have fixed width. Or the time stamp is intentionally truncated with … which isn’t a good idea as time stamps might need to be verified to the second for whatever reason.
brubell
Learn User Page
Post by brubell »
Hi - thank you for reporting this issue. I'm able to reproduce the view from the screenshot and have filed a bug with the Adafruit IO development team. There is no ETA for when this will be fixed, however, this thread will be updated once we have patched and deployed a fix.
