Is there a way that I can push the time stamp with MQTT data to io.adaafruit.com? I have connected sensors to ESP32 which will be in sleep mode but will collect data every 1 minute. I need to send the queued data points every 10 minutes with the correct time stamp that data has been acquired.
Thank You in Advance
MQTT publish with Time stamp
- jwcooper
Re: MQTT publish with Time stamp
You can do this with the HTTP API, batch multiple records and include the timestamp:
https://io.adafruit.com/api/docs/#creat ... ta-records
I don't believe you can send the timestamp with MQTT.
