I have spent the past six hours trying to do the following.
I modified the Adafruit IO subscribe example to control some devices for my hydroponic garden. The example works on my esp32, but what I wrote doesn't–I get something like a brownout error.
This works perfectly:
// Adafruit IO Subscription Example
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
// set up the 'counter' feed
AdafruitIO_Feed *counter = io.feed("counter");
// start the serial connection
Serial.begin(115200);
// wait for serial monitor to open
while(! Serial);
Serial.print("Connecting to Adafruit IO");
// start MQTT connection to io.adafruit.com
io.connect();
// set up a message handler for the count feed.
// the handleMessage function (defined below)
// will be called whenever a message is
// received from adafruit io.
counter->onMessage(handleMessage);
// wait for an MQTT connection
// NOTE: when blending the HTTP and MQTT API, always use the mqttStatus
// method to check on MQTT connection status specifically
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
delay(500);
// Because Adafruit IO doesn't support the MQTT retain flag, we can use the
// get() function to ask IO to resend the last value for this feed to just
// this MQTT client after the io client is connected.
counter->get();
// we are connected
Serial.println();
Serial.println(io.statusText());
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
io.run();
// Because this sketch isn't publishing, we don't need
// a delay() in the main program loop.
// this function is called whenever a 'counter' message
// is received from Adafruit IO. it was attached to
// the counter feed in the setup() function above.
void handleMessage(AdafruitIO_Data *data) {
Serial.print("received <- ");
Serial.println(data->value());
#include "config.h"
// set up the 'test' feed
AdafruitIO_Feed *waterinletonoff = io.feed("waterinletonoff");//12
AdafruitIO_Feed *phuppumponoff = io.feed("phuppumponoff");//16
AdafruitIO_Feed *drainpumponoff = io.feed("drainpumponoff");//17
AdafruitIO_Feed *heateronoff = io.feed("heateronoff");//2
AdafruitIO_Feed *circpumponoff = io.feed("circpumponoff");//7
AdafruitIO_Feed *fansonoff = io.feed("fansonoff");//4
AdafruitIO_Feed *uvlightonoff = io.feed("uvlightonoff");//22
AdafruitIO_Feed *aeratoronoff = io.feed("aeratoronoff");//10
AdafruitIO_Feed *bloomlight = io.feed("bloomlight");//19
AdafruitIO_Feed *humidifieronoff = io.feed("humidifieronoff");//5
AdafruitIO_Feed *veglight = io.feed("veglight");//18
int FILL = 4;//12
int PHUP = 16;//21
int DRAIN = 17;//15
int HEAT = 5;//2
int CIRC = 18;//7
int FANS = 19;//4
int UV = 21;//22
int AER = 3;//10
int BLOOM = 1;//18
int HUM = 22;//5
int VEG = 23;//17
while(! Serial);
pinMode(FILL, OUTPUT);//12
pinMode(PHUP, OUTPUT);//21
pinMode(DRAIN, OUTPUT);//15
pinMode(HEAT, OUTPUT);//2
pinMode(CIRC, OUTPUT);//7
pinMode(FANS, OUTPUT);//4
pinMode(UV, OUTPUT);//22
pinMode(AER, OUTPUT);//10
pinMode(BLOOM, OUTPUT);//18
pinMode(HUM, OUTPUT);//5
pinMode(VEG, OUTPUT);//17
delay(1000);
io.connect();
waterinletonoff->onMessage(handleMessage12);//12
phuppumponoff->onMessage(handleMessage16);
drainpumponoff->onMessage(handleMessage17);
heateronoff->onMessage(handleMessage2);//2
circpumponoff->onMessage(handleMessage7);//7
fansonoff->onMessage(handleMessage4);//4
uvlightonoff->onMessage(handleMessage22);
aeratoronoff->onMessage(handleMessage10);//10
bloomlight->onMessage(handleMessage19);
humidifieronoff->onMessage(handleMessage5);//5
veglight->onMessage(handleMessage18);
Serial.print(".");
delay(1000);
waterinletonoff->get();//12
phuppumponoff->get();//16
drainpumponoff->get();//17
heateronoff->get();//2
circpumponoff->get();//7
fansonoff->get();//4
uvlightonoff->get();//22
aeratoronoff->get();//10
bloomlight->get();//19
humidifieronoff->get();//5
veglight->get();//18
// we are connected
Serial.println();
io.run();
// this function is called whenever a 'test' message
// the test feed in the setup() function above.
void handleMessage12(AdafruitIO_Data *data) {
digitalWrite(FILL, data->toPinLevel());
void handleMessage16(AdafruitIO_Data *data) {
digitalWrite(PHUP, data->toPinLevel());
void handleMessage17(AdafruitIO_Data *data) {
digitalWrite(DRAIN, data->toPinLevel());
void handleMessage2(AdafruitIO_Data *data) {
digitalWrite(HEAT, data->toPinLevel());
void handleMessage7(AdafruitIO_Data *data) {
digitalWrite(CIRC, data->toPinLevel());
void handleMessage4(AdafruitIO_Data *data) {
digitalWrite(FANS, data->toPinLevel());
void handleMessage22(AdafruitIO_Data *data) {
digitalWrite(UV, data->toPinLevel());
void handleMessage10(AdafruitIO_Data *data) {
digitalWrite(AER, data->toPinLevel());
void handleMessage19(AdafruitIO_Data *data) {
digitalWrite(BLOOM, data->toPinLevel());
void handleMessage5(AdafruitIO_Data *data) {
digitalWrite(HUM, data->toPinLevel());
void handleMessage18(AdafruitIO_Data *data) {
digitalWrite(VEG, data->toPinLevel());
18:25:19.169 -> ets Jun 8 2016 00:22:57
18:25:24.739 ->
18:25:24.739 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
18:25:24.739 -> configsip: 0, SPIWP:0xee
18:25:24.739 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
18:25:24.739 -> mode:DIO, clock div:2
18:25:24.777 -> load:0x3fff0030,len:1344
18:25:24.777 -> load:0x40078000,len:13836
18:25:24.777 -> load:0x40080400,len:3608
18:25:24.777 -> entry 0x400805f0
18:25:25.093 ->
Best,
Aidan
