I am using the MQTT time function to get the time which I then successfully upload to a dashboard using an ESP32.
To my understanding, the time is in the format of a char pointer, which I then upload the following to my dashboard as: (char *)timehours.lastread
However, I want to correct this for my time zone.
How can I convert this to an int so I can subtract from it?
I've tried to use the atoi function and others but I'm having trouble.
Aidan
MQTT time feature
- aidan_the_tinkerer
Re: MQTT time feature
Ended up using the MQTT time example instead
