Im using an ESP32 with Arduino Tried the example from the library but its using MQTT. I am doing multiple .save on 4 values and when I added the example time which attaches it to the handler I get multiples responses back.
Is thera a way to do a single GET and get a single response?
How to GET the time on https
- adafruit_support_carter
Re: How to GET the time on https
Checkout how the code from this guide uses AIO to get time:
https://learn.adafruit.com/super-simple ... -using-aio
See how the TIME_URL is setup. The &fmt parameter can vary. That code uses a format that makes parsing the values easy.
- PabloOyarzo
The only issue is that code is on python, not on C++ for arduino
