Adafruit_io/client.py modules platform etc not found
paulskpt
Post by paulskpt »
Trying to run a script that imports the module Adafruit_io.
In my script is the line: ```from Adafruit_IO import Client, Feed, Data, RequestError```.
In /lib/adafruit_io/client.py are the module imports:
import platform
import pkg_resources
import re
from urllib.parse import urlparse
from urllib.parse import parse_qs
The re modules is built-in CPY.
CPY reports import errors for the modules:
- platform;
- pkg_resources;
- urllib.
I don't have these modules installed on my MAGTAG. They results in 'ImportError's.
I tried to find these modules on Github/Adafruit.com but no success.
Anyone that can give my advice to resolve this problem?
rooppoorali
Re: Adafruit_io/client.py modules platform etc not found
Post by rooppoorali »
Hello, have you tried the suggestion mentioned here for pkg_resources ?
https://stackoverflow.com/questions/744 ... -resources
paulskpt
Post by paulskpt »
Thank you. The discussion in the link is about modules for - let's say - installations of Python on a Raspberry Pi or other linux system.
I am using it on a microcontroller with CircuitPython v8 installed. I need modules from some Adafruit_CircuitPython_<module> repo.
adafruit_support_carter
This looks like a general issue with using CircuitPython libraries. See here for info on working with library modules:
https://learn.adafruit.com/welcome-to-c ... -libraries
Are you following a guide? If so, please link to it.
paulskpt
Post by paulskpt »
Thank you. No, I am not following a guide. I am wanting to use parts of examples that I think are usefull to what I have in mind to acomplish.
I have 'the world' on Adafruit CircuitPython libraries installed on one of the drives of my desktop PC on which I am doing the developments for my projects.
The latest version of the CPY firmware is flashed onto the device. Sure, I copy the necessary libraries onto the 'CIRCUITPY' drive of the device.
Regularly I update the important libraries/bundles. With the Windows Explorer of MS Windows 11 I did a search for 'platform', 'pkg_resources' and 'urllib'. Results: negative.
I just saw that urllib is a library that is created for "normal" Python. (see https://docs.python.org/3/library/urllib.html
danhalbert
Post by danhalbert »
Those modules are not available in CircuitPython. adafruit_io (from https://github.com/adafruit/Adafruit_IO_Python) is a library for use with CPython, not with CircuitPython. If you'd like to use AdafruitIO with CircuitPython, see the examples in various guides, such as https://learn.adafruit.com/iot-pyportal ... cuitpython
paulskpt
Post by paulskpt »
Thank you Dan for the clarification. Sometimes I loose track with all these different 'families'.
Case closed.
