How many IO devices per user account?
by fmbfla on Sun Sep 13, 2015 10:32 pm
How many IO devices per user account do you currently allow to simultaneously post DATA?
I am guessing 1 because when I try 2 neither can connect with the default tutorials provided in the sketches of the Arduino.
I figure if I space the uploads far enough apart it might be possible but I think the username login at your end might prohibit it( I do understand the problem of a DOS).
Are multiple IO devices in the future for users?
You need not reply with a long explanation.
I know your busy running the show a simple
"yes, multiple devices are ok/will be implemented"
or
"no they aren't and wont be per user name"
fmbfla
Re: How many IO devices per user account?
by jwcooper on Sun Sep 13, 2015 10:36 pm
There isn't a limit currently, just a throttle. You can see the data policies currently implemented in the https://learn.adafruit.com/adafruit-io guide.
If you're using the MQTT library, make sure you are setting a unique ID for the CLIENTID: https://github.com/adafruit/Adafruit_MQ ... 66.ino#L44
If the ID isn't unique, the second device will disconnect the first device.
jwcooper
by fmbfla on Sun Sep 13, 2015 10:39 pm
WOW, that was fast I had to edit my post to contain the simultaneous part, But thank you for the answer and the link on the throttle.
Drew
fmbfla
