Setting coordinates with the Map dashboard item
by jdoscher on Mon Sep 14, 2015 7:28 pm
Is it possible to set the GPS coordinate values using the map widget? I'd like to run a python script to read the latitude and longitude of the pinpoint set on an IO map.
Jay
jdoscher
Re: Setting coordinates with the Map dashboard item
by jwcooper on Tue Sep 15, 2015 10:36 am
Not yet, but I see no reason we couldn't add this as a new feature in the future. Seems like a good idea if we can get the UI right. I'll create an issue for it in our tracker.
jwcooper
by jdoscher on Tue Sep 15, 2015 10:48 am
That would be cool- I'm thinking of a basic map control where you'd zoom in/out and pan, but drop a pin for the coordinates you want. Thanks!
jdoscher
