I keep getting connection failed
by alanm on Fri Sep 18, 2015 10:51 pm
I have a HUZZAH ESP8266 that reads a DHT22 sensor. It was working fine then one day it stopped connecting to io.adafruit. Any suggestions. I also have another ESP8266 connected to a motion sensor that was also working fine and no longer connects.
Below is what I'm getting in the serial monitor. Any ideas why this is happening? I also tried to reset the API key and that also did not change anything. Any help would be appreciated.
WiFi connected
IP address:
192.168.1.10
Connecting to Adafruit IO... Connection failed
Retrying connection...
Connection failed
Connection failed
alanm
Re: I keep getting connection failed
by xjfo on Fri Sep 18, 2015 11:04 pm
I am experiencing the same issue.
xjfo
by fmbfla on Fri Sep 18, 2015 11:06 pm
I think that it is on there end, as my little Arduino also will not connect anymore. Do not fret try the button sketch if it is available for your Wi-Fi device. I am pretty sure that it is on their end and they will fix it
fmbfla
by alanm on Fri Sep 18, 2015 11:15 pm
Thats is what I was hoping...At least I know its not just me, thanks for the replies!
alanm
by jwcooper on Fri Sep 18, 2015 11:55 pm
Can you try again? I restarted the server. Will enable more monitoring on the MQTT components.
jwcooper
by xjfo on Sat Sep 19, 2015 12:01 am
That fixed my connection issue. Thanks!
xjfo
by alanm on Thu Sep 24, 2015 9:44 am
Yep fixed my problem also...Thanks!
alanm
