Adafruit_MQTT_Subscribe reliability issue
by hwiguna on Mon Sep 21, 2015 11:06 pm
Thanks for the MQTT libraries for the ESP8266. It works great with adafruit.io.
However, there appears to be a bug with Adafruit_MQTT_Subscribe. It works most of the time, but about every 8 message received, the message would be lost and the ESP would reconnect.
This happens with the digital_out example with no modifications other than the wifi credentials.
I created the feed and dashboard element as instructed in the sketch comment.
Let me know what I could do to help pinpoint the issue further.
PS: Going the opposite direction works great! I've been able to reliably send button and potentiometer states to adafruit.io.
hwiguna
Re: Adafruit_MQTT_Subscribe reliability issue
by tdicola on Tue Sep 22, 2015 7:13 pm
That's odd, just to check though is it the ESP8266 example in the MQTT library here: https://github.com/adafruit/Adafruit_MQ ... sp8266.ino ? If so is it that after changing the subscribed to feed (onoff) 8 times you see the sketch reconnect to AIO and lose the last message?
tdicola
by hwiguna on Tue Sep 22, 2015 11:28 pm
Sorry guys, it's user error! 100% my bad.
I forgot that I was messing with the timeout parameter.
It becomes unreliable because I lowered that timeout to 500.
Leaving timeout at 1000 works FLAWLESSLY.
Does the library support non-blocking check similar to Serial.available()?
hwiguna
by adafruit2 on Wed Sep 23, 2015 11:25 am
at this time no there's no callback support
adafruit2
Site Admin
by tdicola on Wed Sep 23, 2015 11:44 am
Oh no problem, glad it was an easy fix. There's no non-blocking mode yet, but you can tweak how long it waits for data to be received by adjusting one of the #define values. For the ESP8266 check out the Adafruit_MQTT_Client.h file and its MQTT_CLIENT_READINTERVAL_MS value: https://github.com/adafruit/Adafruit_MQ ... .h#L29-L30 It's set to 10 milliseconds by default which means to will wait 10 miliseconds at a time for new data to be received. This means you could call readSubscriptions with a 10 millisecond timeout and it would only do one interation (don't pass in a smaller timeout though, it looks like the code wouldn't handle a timeout below the read interval right now). So for example you could experiment with setting the MQTT_CLIENT_READINTERVAL_MS to 1 and then calling readSubscriptions with a 1 or 2 millisecond timeout to do a faster check.
tdicola
