The Welcome Project is no longer working for me
by miked13 on Fri Oct 09, 2015 12:07 pm
I have "No Data Available" shown on the slider logger and when I adjust the slider I see nothing and nothing moves. IF I go to edit the logger it shows my last value was at 64 but shows no historic data.
I'm using win 7 64 bit pro and Chrome. Any Ideas?
miked13
Re: The Welcome Project is no longer working for me
by uniontownlabs on Wed Oct 14, 2015 1:34 pm
Want to give this a shot again? It might have been resolved with some recent bug fixes.
uniontownlabs
by miked13 on Tue Oct 20, 2015 9:15 pm
Sorry for the delay. The example still isn't working for me. Says No Data Available.
miked13
by jwcooper on Wed Nov 04, 2015 12:02 am
When you load the dashboard, is there a bright red line below the header? Websockets need to work in order for the dashboard to communicate properly.
Are you able to create your own dashboard, or your own feed within the welcome dashboard? You can create a test feed by creating a new block in the welcome dashboard, and just name it whatever you want. Choose the slider, and see if that works?
jwcooper
by miked13 on Thu Nov 12, 2015 11:08 am
no red line. I got the example finally working again. I had to create a new one almost from scratch for it to work again and even then it's like every few tries it stops working.
miked13
cron
