Particle Photon Support
by willy332 on Tue Oct 20, 2015 6:39 pm
I'm a newbie and this is probably an obvious question, but can you get Adafruit IO to work with a Particle photon, and how? Thank You for any replies.
willy332
Re: Particle Photon Support
by dwfick on Mon Oct 26, 2015 8:38 pm
For the REST API, I recently got this working using the library example files "Adafruit_IO_Arduino.cpp", "Adafruit_IO_Arduino.h", "Adafruit_IO_Client.cpp", and "Adafruit_IO_Client.h".
In the include files replace
#include "Arduino.h"
..with
#include "application.h"
..and replace the references to the "Client" class with the "TCPClient" class. And remove this:
#include "Client.h"
Declare the TCPClient in your application -
TCPClient client;
Surprisingly, the TCPClient class supports the readBytesUntil() member function used in the Adafruit library, even though I can't find any documentation that it does..
-d
dwfick
by willy332 on Tue Oct 27, 2015 7:24 am
Thanks so much! I will try this when I get back home!
willy332
by tkurtz on Wed Nov 18, 2015 6:35 pm
Hi, Did you get this working? I'd also like to use my Photon but would love to see actual code for the .ino, .cpp and .h files. Thank you!
tkurtz
