Creating a dynamic group name
by daemach on Sun Nov 01, 2015 12:09 pm
My new project is attempting to use AIO groups, creating both the groups and the 6 feeds that comprise them on the fly. To do this, I need to use a dynamic group name that includes a unique serial number/ID. The ESP.getChipID and ESP.getFlashID functions both return a unique ID that can be concatenated to increase entropy.
The problem is that the group names have to be stored in PROGMEM, and PROGMEM really,really wants to have a specific string to work with - not something concatenated on the fly. How do I get around this issue???
From the group_sensors.ino file (my hack, anyway) - this doesn't work, of course - just demonstrating what I need to do:
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, MQTT_SERVER, AIO_SERVERPORT, MQTT_CLIENTID, MQTT_USERNAME, MQTT_PASSWORD);
/****************************** Feeds ***************************************/
String serialNumber = String(ESP.getChipId()) + String(ESP.getFlashId());
// Setup a group called 'weather' for publishing changes.
// Notice MQTT group CSV paths for AIO follow the form: <username>/groups/<groupname>/csv
const char AQ_FEED[] PROGMEM = AIO_USERNAME "/groups/airQuality_" + serialNumber + "/csv";
Adafruit_MQTT_Publish airQuality = Adafruit_MQTT_Publish(&mqtt, AQ_FEED);
daemach
Re: Creating a dynamic group names
by daemach on Wed Nov 04, 2015 12:02 pm
I could really use an answer for this. I have to be able to use dynamic group names or the project won't fly :/
daemach
by jwcooper on Wed Nov 04, 2015 12:07 pm
You might have better luck with this in an ESP specific forum, as it's not really IO specific. Unfortunately, I don't have the answer to this one.
jwcooper
by daemach on Wed Nov 04, 2015 12:18 pm
FWIW, a serial number could come from anywhere. When I did this project with an Uno, I pulled it from a 1MB SPI flash chip.
From the IO side, is there a way to do this without storing this particular string in progmem so we don't have these restrictions out of the gate? Being able to only use a single device on this service without manually modifying and uploading new source code for each device seems limiting :/
daemach
by jwcooper on Wed Nov 04, 2015 12:26 pm
I see what you're saying. It does involve the mqtt library due to the PROGMEM. Can you create an issue in that repository?
https://github.com/adafruit/Adafruit_MQTT_Library
I didn't specifically code that library, and others may be able to help out better on this one.
jwcooper
