Radio buttons or Rotary selector switch.
by miked13 on Thu Nov 12, 2015 4:19 pm
Is there any way to make a radio button. I'm working on a project where i have a state machine with a few states. I want to use a selector switch to changes those states. I'm working on 2 projects that I could really use this for. 1 like an A/C system for a Car thing. where you select between upper, lower, defrost, etc... The other is an LED light project with NEO Pixels. I have 30 patterns programmed in and i want a rotary or drop down box where i can name each state and then choose that state.
miked13
Re: Radio buttons or Rotary selector switch.
by jwcooper on Thu Nov 12, 2015 4:24 pm
Right now we just have the toggle button, and the push button. I think a radio button type of block could be something others could use as well. I'll pass it along and see if we can build it out.
In the meantime, you may need to either use the toggle button, or a few push buttons lined up.
jwcooper
