IO cloud cam - issue getting images into feed
by subrosa on Thu Nov 12, 2015 4:34 pm
I'm following the Adafruit IO guide: https://learn.adafruit.com/cloud-cam-co ... dafruit-io
I ended up having to upgrade to Jessie to run the latest Node.JS, but that hasn't been the problem.
paul@sierra /tmp/aio_cam $ sudo adafruit-io camera start -f PiCamBackyard -m false -r 5
This command automatically creates the PiCamBackyard feed, and I add that feed to my dashboard...but I never get any images.
I see the process running correctly:
paul@sierra /tmp/aio_cam $ ps -efww | grep raspistill
root 3074 3062 0 12:26 ? 00:00:00 /opt/vc/bin/raspistill --timelapse 5000 --timeout 999999999 --quality 10 --nopreview --output /tmp/aio_cam/cam.jpg --width 640 --height 480
As you notice, I testing these with sudo, but the same result happen with a normal user.
Any thoughts?
subrosa
Re: IO cloud cam - issue getting images into feed
by subrosa on Fri Nov 13, 2015 3:32 am
Hrm, seems to be working now.
I guess there might be a timeout involved.
subrosa
