Dashboard not showing feed change using curl
by richarduk on Sat Nov 14, 2015 4:29 pm
I have a yun, the yun can change the feed value and the dash board shows the changes. I can also see the changes when I query it with curl and a https call. If I use a curl call to set the value the dash board does not update. But the value does when I view it with the same curl call that viewed the changes submitted by the yun.
The dashboard is from the yun example.
To get the value:
curl  http://io.adafruit.com/api/feeds/button.json?X-AIO-Key= My Key
To set the value I used a file: set_button.json
{"last_value":1}
To clear it a file: clear_button.json
{"last_value":0}
The curl call is:
curl -H "Content-Type: application/json" -X PUT --data @set_button.json http://io.adafruit.com/api/feeds/button.json?X-AIO-Key= My Key
Any ideas?
Thanks, Richard.
richarduk
Re: Dashboard not showing feed change using curl
by awall on Sat Nov 14, 2015 6:55 pm
Hi Richard, i discussed this in the Bug forum (see https://github.com/adafruit/io-issues/issues/70) and I was told that "last_value" was designed to be a read-only property.
Currently this is not enforced, so you can do a PUT or a PATCH of "last_value" but it works inconsistently in some views and not in others.
So the correct (and working) ways to send data to a feed is to use a POST with "value":
curl -H "Content-Type: application/json" -X POST -d "{\"value\":\"123\"}" -H "x-aio-key: ...ABCD..." http://io.adafruit.com/api/feeds/<...feednumber...>/data.json
And if you need to update the value of an existing data point, then use PUT or PATCH with "value":
curl -H "Content-Type: application/json" -X PUT -d "{\"value\":\"777\"}" -H "x-aio-key: ...ABCD..." http://io.adafruit.com/api/feeds/<...feednumber...>/data/<...datapoint_id...>.json
I think it's time for me to post a complete CURL guide for REST API...
Regards
Andrea
awall
by richarduk on Sat Nov 14, 2015 7:46 pm
Thanks for the info, seems the feeds documentation needs to be updated as that says to use last_value to update an existing value. I never got as far as reading the part about the data POST. I guess that part in feeds can be just deleted to stop confusing noobs like me. :)
Thanks for the help, working now.
richarduk
by jwcooper on Mon Nov 16, 2015 1:39 pm
I've removed the old docs. Thanks for the reminder. ;)
The latest docs are found here:
https://io.adafruit.com/api/docs
last_value is indeed supposed to be read-only.
jwcooper
