CURL guide for REST API
by awall on Sat Nov 14, 2015 8:07 pm
I've played quite a bit around Adafruit IO REST API using CURL, so I've decided to post a complete guide with examples for all the available API.
All the examples assume the following (brackets must not be included):
- <AIOkey> must be replaced with your own AIO Key;
- <FEEDnum> must be replaced with the feed number (e.g. 1234);
- <FEEDname> must be replaced with the feed name (e.g. MyFeed);
- <DATAid> must be replaced with the ID of the feed data;
- Data in and out is provided in JSON format, but examples can be changed to also support CSV and XML.
List of Feeds
curl -H "Content-Type: application/json" -X GET -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds.json
Create a new Feed
curl -H "Content-Type: application/json" -X POST -d "{\"name\":\"<FEEDname>\"}" -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds.json
Get an existing feed
curl -H "Content-Type: application/json" -X GET -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds/<FEEDnum>.json
Update a feed (send new data)
curl -H "Content-Type: application/json" -X POST -d "{\"value\":\"123\"}" -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds/<FEEDnum>/data.json
Delete an existing feed
curl -H "Content-Type: application/json" -X DELETE -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds/<FEEDnum>.json
Get all the data in a feed
curl -H "Content-Type: application/json" -X GET -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds/<FEEDnum>/data.json
Get an existing data object
curl -H "Content-Type: application/json" -X GET -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds/<FEEDnum>/data/<DATAid>.json
Update an existing data object
curl -H "Content-Type: application/json" -X PUT -d "{\"value\":\"777\"}" -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds/<FEEDnum>/data/<DATAid>.json
or as an alternative
curl -H "Content-Type: application/json" -X PATCH -d "{\"value\":\"777\"}" -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds/<FEEDnum>/data/<DATAid>.json
Delete an existing data object
curl -H "Content-Type: application/json" -X DELETE -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds/<FEEDnum>/data/<DATAid>.json
Send a data object (based on feed name)
curl -H "Content-Type: application/json" -X POST -d "{\"value\":\"456\"}" -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds/<FEEDname>/data/send.json
Get last data object
curl -H "Content-Type: application/json" -X GET -H "x-aio-key: <AIOkey>" http://io.adafruit.com/api/feeds/<FEEDnum>/data/last.json
Optional parameters
- For verbose output use
curl -v
- To invoke commands with SSL use
curl -k using URL https://io.adafruit.com/api/feeds/
Hope this helps out there using REST API.
Regards
Andrea
awall
Re: CURL guide for REST API
by richarduk on Sun Nov 15, 2015 3:33 pm
That is great :) I will be referring to your post a lot. Thumbs up. :)
richarduk
by jwcooper on Mon Nov 16, 2015 1:22 pm
Thanks for posting and sharing this for everyone else to use!
jwcooper
