example code for Qos 0 and 1
by fapuc2 on Mon Nov 23, 2015 4:02 am
Has anyone experienced example of code that how to use the library MQTT
that support enough for QoS 0 and 1
Regards
fapuc2
Re: example code for Qos 0 and 1
by uniontownlabs on Mon Nov 23, 2015 11:58 am
Which language and platform are you planning on using? Raspberry Pi (with Node.js, Ruby, Python), Arduino, ESP8266, etc
uniontownlabs
by fapuc2 on Mon Nov 23, 2015 1:41 pm
Thanks for the reply,
I successfully tested this example
I would add with quality of service 0 or 1.
with ESP8266 environment "arduino-1.6.5-R5" and Adafruit MQTT Library version=0.12
My application is control actuator skylight roof
through feed "lamp" and its effective closure with feed "button"
https://io.adafruit.com/fapuc2
  Adafruit MQTT Library ESP8266 Example
  Must use ESP8266 Arduino from:
    https://github.com/esp8266/Arduino
  Works great with Adafruit's Huzzah ESP board:
  ----> https://www.adafruit.com/product/2471
  products from Adafruit!
  Written by Tony DiCola for Adafruit Industries.
  Adafruit IO example additions by Todd Treece.
  MIT license, all text above must be included in any redistribution
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
/****************************** Pins ******************************************/
  #define LAMP            2  // Led o comando Relè
  #define BUTTON          0  // switch fine corsa  normalmente aperto            //****************
/************************* WiFi Access Point *********************************/
#define WLAN_SSID       "............"
#define WLAN_PASS       "......................."
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    "........."
#define AIO_KEY         "................................."
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// Store the MQTT server, client ID, username, and password in flash memory.
// This is required for using the Adafruit MQTT library.
const char MQTT_SERVER[] PROGMEM    = AIO_SERVER;
// Set a unique MQTT client ID using the AIO key + the date and time the sketch
// was compiled (so this should be unique across multiple devices for a user,
// alternatively you can manually set this to a GUID or other random value).
const char MQTT_CLIENTID[] PROGMEM  = __TIME__ AIO_USERNAME;
const char MQTT_USERNAME[] PROGMEM  = AIO_USERNAME;
const char MQTT_PASSWORD[] PROGMEM  = AIO_KEY;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, MQTT_SERVER, AIO_SERVERPORT, MQTT_CLIENTID, MQTT_USERNAME, MQTT_PASSWORD);
/****************************** Feeds ***************************************/
// Setup a feed called 'lamp' for subscribing to changes.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname> //*****************************************************
const char LAMP_FEED[] PROGMEM = AIO_USERNAME "/feeds/lamp";                  //***
Adafruit_MQTT_Subscribe lamp = Adafruit_MQTT_Subscribe(&mqtt, LAMP_FEED);     //*** Subscribe (Riceve comando x relè motore )
const char BUTTON_FEED[] PROGMEM = AIO_USERNAME "/feeds/button";              //***
Adafruit_MQTT_Publish button = Adafruit_MQTT_Publish(&mqtt, BUTTON_FEED);     //*** Publish   (Trasmette lo stato del fine corsa)
/*************************** Sketch Code ************************************/
// button state
int current = 0;
int currentB = 0;
int last = -1;
int lastB = -1;
  // set pin ingresso uscita  ESP8266
  pinMode(LAMP, OUTPUT);
  pinMode(BUTTON, INPUT_PULLUP);  //**************** "INPU_PULLUP" se ardware manca resistenza fisica di pullup verso +vcc
  Serial.begin(115200);
  Serial.println(F("Adafruit IO Example"));
  // Connect to WiFi access point.
  Serial.println(); Serial.println();
  delay(10);
  Serial.print(F("Connecting to "));
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(F("."));
  Serial.println();
  Serial.println(F("WiFi connected"));
  Serial.println(F("IP address: "));
  Serial.println(WiFi.localIP());
  // listen for events on the lamp feed
  mqtt.subscribe(&lamp);
 // mqtt.subscribe(&button);     //**************** button è solo pubblicato
 // connect to adafruit io
  connect();
  digitalWrite(LAMP,LOW);    // stato iniziale al boot
  digitalWrite(BUTTON,LOW);  // stato iniziale al boot    ***************
  Adafruit_MQTT_Subscribe *subscription;
         // ping adafruit io a few times to make sure we remain connected
         if(! mqtt.ping(3)) {
         // reconnect to adafruit io
         if(! mqtt.connected())
         connect();
// feeds/button ****************************************************************************************************************
       // grab the current state of the button
       current = digitalRead(BUTTON);
       // return if the value hasn't changed    // return se ilvalore non cambia     //**************************
       // if(current == last)                  // abilita questa riga e quella sopra e sotto
       // return;                             // per aspettare il cambio di stato prima di fare nuovo invio
                                             // invece se queste righe commentate questo feeds invia ciclicamente il suo stato
       int32_t value = (current == LOW ? 1 : 0);
       // Now we can publish stuff!
       Serial.print(F("\nSending button value: "));
       Serial.print(value);
       Serial.print("... ");
   if (! button.publish(value))
      Serial.println(F("Failed."));
         else
         Serial.println(F("Success!"));
         delay(5000);                       // *************************************
                                               // 5 secondi // intervallo x ogni invio
              // save the button state
              last = current;
// feeds/lamp ****************************************************************************************************************
    // this is our 'wait for incoming subscription packets' busy subloop
    while (subscription = mqtt.readSubscription(1000)) {
        // we only care about the lamp events
        if (subscription == &lamp) {
        // convert mqtt ascii payload to int
        char *value = (char *)lamp.lastread;
        Serial.print(F("Received: "));
        Serial.println(value);
        int current = atoi(value);
        // write the current state to the power switch tail
        digitalWrite(LAMP, current == 1 ? HIGH : LOW);
// connect to adafruit io via MQTT
void connect() {
  Serial.print(F("Connecting to Adafruit IO... "));
  int8_t ret;
  while ((ret = mqtt.connect()) != 0) {
    switch (ret) {
      case 1: Serial.println(F("Wrong protocol")); break;
      case 2: Serial.println(F("ID rejected")); break;
      case 3: Serial.println(F("Server unavail")); break;
      case 4: Serial.println(F("Bad user/pass")); break;
      case 5: Serial.println(F("Not authed")); break;
      case 6: Serial.println(F("Failed to subscribe")); break;
      default: Serial.println(F("Connection failed")); break;
    if(ret >= 0)
      mqtt.disconnect();
    Serial.println(F("Retrying connection..."));
    delay(5000);
  Serial.println(F("Adafruit IO Connected!"));
fapuc2
by adafruit2 on Mon Nov 23, 2015 8:56 pm
right now we only support QoS 0, you can always subscribe to the same feed you're publishing to, and we have upgraded to 3.1.1 which makes QoS1 a little easier but yah - its not supported right now and no ETA
adafruit2
Site Admin
