Unable to create feeds, dashboards, groups
by lloydxmas on Tue Dec 01, 2015 7:35 am
I'm getting a 500 Internal Server Error (from /feeds.js) upon trying to create a new feed, dashboard, etc. My account is fairly new so I'm not sure if that has something to do with the issue. Thanks for any feedback
lloydxmas
Re: Unable to create feeds, dashboards, groups
by jwcooper on Tue Dec 01, 2015 12:30 pm
Hi, IO was down at this time due to server issues. Please try again when you can. Thanks!
jwcooper
by Shape_Shifter on Fri Dec 11, 2015 10:26 pm
Hi I'm having the same problem at the moment.
Shape_Shifter
by rccarman on Fri Dec 11, 2015 11:02 pm
Getting the same error from the Python client as of 03:00 Z.
Also can't send data in to existing feeds, due to this error.
rccarman
by jwcooper on Fri Dec 11, 2015 11:30 pm
Please try again. I restarted some hung processes.
jwcooper
by rccarman on Fri Dec 11, 2015 11:39 pm
Confirmed this error is gone now. Thanks.
rccarman
by kanthony on Sun Dec 13, 2015 1:06 am
Not sure if this is happening again or not, every example I try including the ones in the docs at https://io.adafruit.com/api/docs/#!/Data/send are returning 500 errors.
kanthony
by rccarman on Mon Dec 14, 2015 12:22 am
The system appeared to die around midnight Z. Appears to be back up again now.
It would be nice if there were a system status page we could check to see if Adafruit thinks everything is up and functioning correctly... Hint, hint...
rccarman
by jwcooper on Mon Dec 14, 2015 11:16 am
We're planning on adding more communication tools, blog/changelog, status page, etc. We just need to balance building out IO and building out the tools for IO.
jwcooper
by aforaste1 on Mon Dec 14, 2015 6:55 pm
I would find the system status page that rccarman describes very useful as well. Or even a simple small green/online radio button status indicator of some sort. I find it makes troubleshooting new aio dashboard projects/code much more difficult without knowing the status until several hours later. Just my 2 cents. Thanks.
aforaste1
