Ruby client library
Ruby client library
by jsc on Sat Dec 05, 2015 8:39 pm
Just getting started with the Ruby client library. Thought I would mention some things I ran into:
1. The github commits say something about removing the hashie dependency from the gemspec, but when I installed the adafruit-io gem and tried to require 'adafruit/io', I had to end up installing and requiring hashie and activemodel.
2. The code is set up to hit localhost:3002. If you want it to hit adafruit.io itself, you have to change the url in client.rb.
With those two changes, it appears to be working.
jsc
cron
