Maps csv string example
by platypus18 on Sun Dec 06, 2015 1:20 pm
Good morning,
I am having trouble constructing a csv string value for the map block. From what I have gleaned from other projects, it seems the format is: <sensor_value>,<decimal lat>,<decimal long>,<elevation>
I am able to submit these values to the feed using the rest API and the values appear when I view the feed data stream, but the data point never appears on the map. This is the hard-coded value I am experimenting with:
0,43.571205,-116.161362,3500.00
I have tried several variations, but always with the same result. What am I missing?
platypus18
