adafruit dashboard
- mindaugasgi
adafruit dashboard
Hello, I have Arduino Uno and Ethernet shield, and I want to connect to adafruit dashboard. When I send URL request from browser, it is work, but I cant connect with Arduino. I found examples with c3300, maybe someone have examples with ethernet shield? Can you help me with it? Do you have some ideas maybe?
- MikeTeachman
Re: adafruit dashboard
Hi... I use an Arduino UNO + Ethernet shield for our hedgehog monitoring dashboard. I cut out some code snips that might help?
The hedgehog dashboard:
https://io.adafruit.com/MikeTeachman/sir-charles
The hedgehog!
https://sites.google.com/site/sircharlesruns/statistics
The code snips for AIO
The hedgehog!
#include <Ethernet.h>
#include "Adafruit_IO_Client.h"
#define AIO_KEY "your aio key"
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetClient client;
Adafruit_IO_Client aio = Adafruit_IO_Client(client, AIO_KEY);
Adafruit_IO_Feed hedgieDistance = aio.getFeed("hhd");
Adafruit_IO_Feed hedgieTemperature = aio.getFeed("hht");
Adafruit_IO_Feed hedgieUptime = aio.getFeed("hhu");
void setup()
setupEthernet();
// Initialize the Adafruit IO client class
aio.begin();
void loop()
hedgieTemperature.send(tempsensor.readTempC());
hedgieUptime.send(uptimeInMinutes);
// push accumulated distance to Adafruit IO
hedgieDistance.send(convertCmsToM(nightStats.totalDistanceInCm));
void setupEthernet()
// Serial.println(F("Connecting Arduino to network..."));
// Serial.println();
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0)
// Serial.println(F("DHCP Failed, reset Arduino to try again"));
else
// Serial.println(F("Arduino connected to network using DHCP"));
// Serial.print(F("My IP address: "));
// Serial.println(Ethernet.localIP());
