Is there any reason that dtostrf() does not work wihtin logL
by pierrot10 on Sat Dec 12, 2015 5:03 pm
Good evening,
I am using FONA808 and Feather MO to log location to Adafruit IO:
I follow that tutotial https://learn.adafruit.com/geofencing-with-the-fona-808-and-adafruit-io/testing-the-gps
I configure my Arduino IDE 1.6.5 as is described into the Feather MO tutoria.
All works excepted the function
void logLocation(float latitude, float longitude, float altitude, Adafruit_MQTT_Publish& publishFeed) {
  // Initialize a string buffer to hold the data that will be published.
  char sendBuffer[120];
  memset(sendBuffer, 0, sizeof(sendBuffer));
  int index = 0;
  // Start with '0,' to set the feed value.  The value isn't really used so 0 is used as a placeholder.
  sendBuffer[index++] = '0';
  sendBuffer[index++] = ',';
  // Now set latitude, longitude, altitude separated by commas.
  dtostrf(latitude, 2, 6, &sendBuffer[index]);
  //sprintf(&sendBuffer[index], "%.6f", latitude);
  index += strlen(&sendBuffer[index]);
  dtostrf(longitude, 3, 6, &sendBuffer[index]);
  //sprintf(&sendBuffer[index], "%6f", longitude);
  dtostrf(altitude, 2, 6, &sendBuffer[index]);
  //sprintf(&sendBuffer[index], "%9.6f", altitude);
  // Finally publish the string to the feed.
  sprint(F("Publishing location: "),2);
  sprintln(sendBuffer,2);
  if (!publishFeed.publish(sendBuffer)) {
    sprintln(F("Publish failed!"),2);
    txFailures++;
  else {
    sprintln(F("Publish succeeded!"),2);
    txFailures = 0;
The above function use dtostrf() and wen I compile, the following error message is shown in Serial Terminal
mo808.ino: In function 'void logLocation(float, float, float, Adafruit_MQTT_Publish&)':
mo808:787: error: 'dtostrf' was not declared in this scope
Then, at the top of my sketch, I added stdlib.h
#include <Adafruit_FONA.h>
// For Adafruit IO
#include <Adafruit_MQTT.h>
#include <Adafruit_MQTT_FONA.h>
#include <stdlib.h> // because dtostrf()
But it did not solved my problem.
Is there a way to use dtostrf()?
I tried to use sprintf insetad, but sprintf does not store the value and it display this:
MQTT
Publishing location: 0,,,
Thnak for your advises
pierrot10
Re: Is there any reason that dtostrf() does not work wihtin
by adafruit_support_rick on Sun Dec 13, 2015 5:30 pm
The SAMD run-time library doesn't support dtostrf. But as far as I know, sprintf should work. I don't know why you're having problems with it.
Although this line doesn't look right
The "%.6f" is wrong. You need a minimum field width before the '.'
by pierrot10 on Sun Dec 13, 2015 5:39 pm
Dear Rick
Thank for your information.
Have a nice evening
Cheers
pierrot10
