Dynamic group names
Dynamic group names
by daemach on Tue Dec 15, 2015 9:06 pm
Here's how I got dynamic group names to work, based on the group_sensor sketch.
  /****************************** Feeds ***************************************/
// Setup a group called 'weather' for publishing changes.
// Notice MQTT group CSV paths for AIO follow the form: <username>/groups/<groupname>/csv
// const char WEATHER_FEED[] PROGMEM = AIO_USERNAME "/groups/weather/csv";
char CUREOMATIC[100];
Adafruit_MQTT_Publish cureomatic = Adafruit_MQTT_Publish(&mqtt, CUREOMATIC);
/*************************** Sketch Code ************************************/
  String macAdx = WiFi.macAddress();
  macAdx.replace(":","");
  String groupName = "CureOMatic_" + String(ESP.getChipId()) + macAdx;
  String feedName = String(AIO_USERNAME) + "/groups/" + groupName + "/csv";
  feedName.toCharArray(CUREOMATIC, feedName.length());
daemach
Re: Dynamic group names
by jwcooper on Thu Dec 17, 2015 11:09 pm
Thank you for sharing this code. This is surely going to help other people trying to do the same things. We'll try to get something similar into our repository as an example as well.
jwcooper
by daemach on Sun Dec 20, 2015 3:21 pm
I'm looking forward to seeing a more elegant solution ;) This is just a hack to get it working!
daemach
cron
