Making a Command Line Interface for Adafruit.io
by rjsteinert on Thu Dec 17, 2015 10:32 pm
I have a lot of other commands that pull data from devices. I would like to be able to Unix pipe that data to a command that pushes the data to the Adafruit.io. For example:
pull-from-sensor | adafruit --feed XYZ --aio-key ABC
So I created a simple CLI that does that :)
https://github.com/openpipekit/opk-cli--adafruit-io
As a next step, I would like that if the pull command returns a bunch of sensors in JSON, that it creates feeds on Adafruit.io, puts them in a group, and then starts piping the data over. Is anyone else interested in this as well?
rjsteinert
Re: Making a Command Line Interface for Adafruit.io
by jwcooper on Thu Dec 17, 2015 11:07 pm
This is cool, more clients the merrier!
We also have an open source command line client written in node.js as well: https://github.com/adafruit/adafruit-io-node#client
jwcooper
by rjsteinert on Fri Dec 18, 2015 10:53 am
Thanks for the tip! I thought that library was just a Node library, didn't realize it was a CLI.
rjsteinert
