Input is dead again
Input is dead again
by rccarman on Sun Dec 20, 2015 1:36 am
Once again adafruit.io is failing to accept input:
File "therms.py", line 19, in <module>
aio.create_data('Therms', data)
File "C:\Python\3.4\lib\site-packages\adafruit_io-1.0.0-py3.4.egg\Adafruit_IO\client.py", line 144, in create_data
File "C:\Python\3.4\lib\site-packages\adafruit_io-1.0.0-py3.4.egg\Adafruit_IO\client.py", line 72, in _post
File "C:\Python\3.4\lib\site-packages\adafruit_io-1.0.0-py3.4.egg\Adafruit_IO\client.py", line 56, in _handle_error
Adafruit_IO.errors.RequestError: Adafruit IO request failed: 500 Internal Server Error
rccarman
Re: Input is dead again
by thedarkhawk on Sun Dec 20, 2015 8:20 am
Same Here, stopped around 12h ago..
thedarkhawk
by jwcooper on Sun Dec 20, 2015 1:38 pm
Can you try again, should be back.
We're mitigating this by migrating to new servers, hopefully on Monday. Bigger, and more servers for IO soon.
jwcooper
by pellico on Sat Jan 09, 2016 3:22 pm
UPDATE/SOLVED: I deleted my AIO account completely and created a new one and now it works.
FWIW, The previous/first account I'd filled up when I tried to create a feed and the dialog never went away so I clicked a number of times and when I manually closed the dialog my feed window was full of created feeds. Maybe that borked the account even though I deleted those feeds.
Is the standard Python Adafruit IO library supposed to work? Running Ubuntu 14.04 64bit and seem to be having problems.
I am trying out Adafruit-IO for the first time and getting 500 Internal Server Error on the simplest of things like creating a feed.
test0.py
# Import library and create instance of REST client.
from Adafruit_IO import Client, Feed
aio = Client('_myAIOkeyHere_')
# Create Feed object with name 'Foo'.
feed = Feed(name='Bar')
#feed = Feed(name='Foo')
# Send the Feed to IO to create.
# The returned object will contain all the details about the created feed.
result = aio.create_feed(feed)
It creates a feed named Bar but gives this error:
dlarue@myMachine:~/Projects/Arduino/BarometricSensor/AdafruitIO$ python test0.py
  File "test0.py", line 11, in <module>
  File "build/bdist.linux-x86_64/egg/Adafruit_IO/client.py", line 171, in create_feed
  File "build/bdist.linux-x86_64/egg/Adafruit_IO/client.py", line 72, in _post
  File "build/bdist.linux-x86_64/egg/Adafruit_IO/client.py", line 56, in _handle_error
I then manually add data element value "10" via web interface and then the read fails.
# Author: Tony DiCola
# Import Adafruit IO REST client.
# Set to your Adafruit IO key.
ADAFRUIT_IO_KEY = '-myAIOkeyHere-'
# Create an instance of the REST client.
aio = Client(ADAFRUIT_IO_KEY)
# Now read the most recent value from the feed 'Foo'.  Notice that it comes
# back as a string and should be converted to an int if performing calculations
# on it.
data = aio.receive(504993)
#data = aio.receive('Bar')
#data = aio.receive('bar')
print('Retrieved value from Foo has attributes: {0}'.format(data))
print('Latest value from Foo: {0}'.format(data.value))
# Send a string value 'bar' to the feed 'Foo', again creating it if it doesn't
# Send a value to the feed 'Foo'.  This will create the feed if it doesn't
# exist already.
#aio.send('Foo', 42)
output:
dlarue@myMachine:~/Projects/Arduino/BarometricSensor/AdafruitIO$ python test1.py
  File "test1.py", line 17, in <module>
  File "build/bdist.linux-x86_64/egg/Adafruit_IO/client.py", line 106, in receive
  File "build/bdist.linux-x86_64/egg/Adafruit_IO/client.py", line 63, in _get
Adafruit_IO.errors.RequestError: Adafruit IO request failed: 400 Bad Request
pellico
cron
