Can I specify color in either stream block or line chart blo
by rfarmeriowa on Sun Dec 27, 2015 10:28 pm
When I graph two feeds in one line chart block, each feed is automatically a different color (but I apparently can't specify the color). When I list two feeds in a stream block, both feeds are the same color. Can I do either of the following:
1. Allow the selection of a different color for each feed in a stream block (to make it easier to tell them apart)
2. Allow the selection of a color for each feed on a line chart (and then I could match the line chart feed color to the stream block feed color.)
Thanks for any suggestions.
rfarmeriowa
Re: Can I specify color in either stream block or line chart
by jakeloggins on Fri Jan 08, 2016 1:59 pm
I second this request for better labeling of line charts. If I put three feeds in a line chart, they are all different colors, but there is no legend to tell me which feeds those colors represent. I have to add feeds one at a time, remember or write down what the colors represent, and then remember them again each time I look at the dashboard.
jakeloggins
