2015-12-28 11:3:59 - ERROR - feed plantsoil: undefined metho
by Mnelson on Mon Dec 28, 2015 3:35 pm
I have a feed named plantsoil.
This is the part of my code I think might be causing the issue:
// Setup a feed called 'photocell' for publishing changes.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
const char PHOTOCELL_FEED[] PROGMEM = AIO_USERNAME "/feeds/plantsoil";
Adafruit_MQTT_Publish photocell = Adafruit_MQTT_Publish(&mqtt, PHOTOCELL_FEED);
I want the data from variable photocell to feed into my feed named plantsoil but am getting the following error in the dashboard for the feed.
2015-12-28 11:3:59 - ERROR - feed plantsoil: undefined method `feeds' for nil:NilClass
Mnelson
Re: 2015-12-28 11:3:59 - ERROR - feed plantsoil: undefined m
by jwcooper on Mon Dec 28, 2015 4:44 pm
Hi, please try again. I've repaired an issue with your account.
jwcooper
