Using HTTP PUT to update feed
by MrAureliusR on Fri Jan 01, 2016 5:46 am
Hi everyone.
I cannot seem to figure out what the parameter is supposed to be to update the 'last_value' of a feed using an HTTP PUT request. I can use an HTTP request, such as the following:
GET 'http://io.adafruit.com/api/feeds/feednumber?x-aio-key=mykey'
and I get a 200 OK with the feed info.
But when I try and do
PUT 'http://io.adafruit.com/api/feeds/feednumber?x-aio-key=mykey&last_value=value'
I get 400 Error: Bad Request. What is the correct parameter for the last value?
MrAureliusR
Re: Using HTTP PUT to update feed
by MrAureliusR on Sat Jan 02, 2016 3:15 am
After more research, it seems there is a bug and a lapse in the documentation. I posted issue #93 on the GitHub issue tracker. I am able to push updates to the 'last_value', which correctly shows the change, but only in one location. See link for more info: https://github.com/adafruit/io-issues/issues/93
It would be great if the "Guide and Tips" section posted more details about what the proper value names should be. There is only reference to the 'last_value' which seems to be the cause of this bug. Also, http://io.adafruit.com/api/docs/ seems to be down currently.
MrAureliusR
by MrAureliusR on Sat Jan 02, 2016 3:38 am
So, after more reading, you have to use POST to update your feed, at a different URL. I summarized how I got it working in the issue, which I've since closed. Again, I highly recommend updating the "Guide and Tips" section. I would love to do it if I could.
MrAureliusR
by jwcooper on Mon Jan 04, 2016 11:14 pm
The feed last_value is supposed to be read-only. Sending a new data resource to the feed will automatically update the last_value and last_value_at. Any access to being able to update the last_value should have been removed.
And yes, the documentation definitely needs more work yet!
jwcooper
