Adafruit and Raspberry PI receive value and act
by joestahl on Sun Jan 03, 2016 10:06 am
Hello, I'm learning python so sorry for the ignorance in advance.
I'm writing a script to port values from my Raspberry Pi to Adafruit.io and I figured out the sending my sensors data to Adafruit which works but is clunky (I'll clean it up later.)
Now I'm trying to add an "ON"/"OFF" button in Adafruit and then have that received value execute a file or activated a pin (GPIO.LOW). I've gotten the python script to receive the value and I can seem to get the "if" statement to work write.
I code is below and I've highlighted the areas that I'm having issue with.
Any chance someone can take a look?
Start of Copy>
#Import Python Modules
import sys
import time
import Adafruit_DHT
import RPi.GPIO as GPIO
# Import Adafruit IO MGTT Client
from Adafruit_IO import MQTTClient
# Set io.adafruit Key and Username
ADAFRUIT_IO_KEY = 'API key'
ADAFRUIT_IO_USERNAME = 'username'
### not to self, add calculation to conver the value from old to 0 - 100.
# Define IO callback functions
def connected(client):
print 'Connected to Adafruit IO! Listening for feed changes...'
# subscribe to feed in a dashdoard
client.subscribe('Relay')
def disconnected(client):
print 'Disconnect from Adafruit IO!'
sys.exit(1)
def message(client, feed_id, payload):
# feed_id or {0} represents the name of the feed in the message to the Adafruit IO service.
# Payload or {1} represents the value being sent.
print 'Feed {0} recieved new vaule: {1}'.format(feed_id, payload)
if '{0}'.format(feed_id) == 'OFF':
execfile("relaytest.py")
# Create a connection instance using the IO Key and Username
client = MQTTClient(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
#Setup the callback functions define above
client.on_connect = connected
client.on_disconnect = disconnected
client.on_message = message
#connect to Adafruit Server
client.connect()
client.loop_background()
# Print the value and a message if it's over 100. Notice that the value is
# converted from string to int because it always comes back as a string from IO.
data = client.subscribe('Relay')
if data == 'ON':
execfile("/downloads/relaytest.py")
time.sleep(10)
relay = int(data.value)
print('Relay: {0}'.format(relay))
if relay == ON:
print "worked ON"
if relay == ('OFF'):
print "worked OFF"
<end of copy
Copyable window below:
import sys
import time
import Adafruit_DHT
    sys.exit(1)
client.connect()
if data == 'ON':
time.sleep(10)
if relay == ON:
    print "worked ON"
    print "worked OFF"
joestahl
Re: Adafruit and Raspberry PI receive value and act
by joestahl on Sun Jan 03, 2016 6:14 pm
Resolved issue, but I still think the execution could be cleaner.
In the "def message(client, feed_id, payload)"
I added the following if statement.
    # Message function will be called when a subscribed feed has a new value.
    # The feed_id parameter identifies the feed, and the payload parameter has
    # the new value.
    print 'Feed {0} received new value: {1}'.format(feed_id, payload)
    if '{1}'.format(feed_id, payload) == "ON":
       GPIO.output(17, GPIO.LOW)
    if '{1}'.format(feed_id, payload) == "OFF":
       GPIO.output(17, GPIO.HIGH)
I was hoping that I could us var 'relay' instead of the .format version but maybe I can make a var like this
relay = '{1}'.format(feed_id, payload)
if relay == "ON":
do whatever
instead
signed "I like cheese"
joestahl
by Scientist1995 on Fri Jan 25, 2019 3:22 pm
HIE,
my name is soumil shah
here is a code to your problem
or I would say whenever button changes on the website you get a message
# Import standard python modules.
import sys
import time
import random
# Import Adafruit IO MQTT client.
ADAFRUIT_IO_KEY = 'XXXXXXXXXXXXXX'
ADAFRUIT_IO_USERNAME = 'XXXXXX'
IO_FEED = 'XXXXXX'
    print ('Connected to Adafruit IO! Listening for feed changes...')
    client.subscribe('test')
    print ('Disconnect from Adafruit IO!')
    sys.exit(1)
    print ('Feed {0} recieved new vaule: {1}'.format(feed_id, payload))
        print("ON Worked ")
        print("OFF worked ")
client.connect()
while 1:
    data = client.on_message
Reason: removing personal information
Scientist1995
