Is throttling based on feeds or account? Seeing what looks l
by pellico on Mon Jan 11, 2016 1:35 pm
I have 2 feeds, one with a barometric pressure and the other contains the barometric pressure/val to get inches of water. These are sent from a python script with a 20 second delay between the two send() calls. What I see is that the first send(out) is often returning True but the 2nd send(out/3.39..) is often failing and the exception handler is catching it. But sometimes both send() calls are successful.
I can put code in to alternate the send() calls but wanted to know what's the current policy on this?
Thanks.
kPa: 102.32
 in: 30.22
send(out) TRUE
send(out/3.39) TRUE
kPa: 102.32
 in: 30.22
send(out) TRUE
aio.send() error
SLEEPING / RETRY
kPa: 102.32
 in: 30.22
send(out) TRUE
aio.send() error
SLEEPING / RETRY
kPa: 102.32
 in: 30.22
send(out) TRUE
send(out/3.39) TRUE
kPa: 102.32
 in: 30.22
aio.send() error
SLEEPING / RETRY
pellico
Re: Is throttling based on feeds or account? Seeing what loo
by jwcooper on Mon Jan 11, 2016 1:44 pm
Throttling is per account right now. Your feeds all share the same throttle 'pool'.
jwcooper
by pellico on Mon Jan 11, 2016 3:05 pm
jwcooper wrote:Throttling is per account right now. Your feeds all share the same throttle 'pool'.
ok so it sounds like we'll need to put some round robin mechanisms in place on our side. Thanks.
pellico
by jwcooper on Tue Jan 12, 2016 11:56 am
We've also made some changes to throttling. Try again, you might be OK today.
jwcooper
by pellico on Tue Jan 12, 2016 3:17 pm
jwcooper wrote:We've also made some changes to throttling. Try again, you might be OK today.
With a 20 second delay between sends to two different feeds it is now working. At least it did 3 times.
I'm still going to put back the round robin code though.
pellico
