Non-blocking readSubscription()?
by jecottrell on Mon Jan 11, 2016 1:46 pm
Is there a way to implement non-blocking code to read subscriptions?
What is the optimal "timeout" value for the readSubscription function?
while ((subscription = mqtt.readSubscription(2000)))
Thanks,
John
jecottrell
Re: Non-blocking readSubscription()?
by pellico on Mon Jan 11, 2016 3:03 pm
if the readSubscription() timeout value is not working(how did you test it) you could wrap that in a while(true) loop and put a sleep after the while( readSubscription() ) loop.
I didn't see the readSubscription() function as part of the python code so it might be just for embedded controllers. Maybe look at the source code for that function and see what it's doing, or not doing and what the single 'time' parameter is used for.
Doug
pellico
by jecottrell on Mon Jan 11, 2016 5:29 pm
I'm sorry, I missed the important info that this code is on an ESP8266.
I guess the better forum is the Other Supported products. I'll post there, thanks!
jecottrell
by pellico on Mon Jan 11, 2016 6:15 pm
jecottrell wrote:I'm sorry, I missed the important info that this code is on an ESP8266.
if it's an Adafruit IO API then I believe your question does belong here. I only stated I didn't see it in my Python code because I'm only using the Python API but the same rules apply to seeking the answer yourself. Ie look at the code since it's all posted on git and public.
It is possible you found a bug in the readSubscription(t) API the work-around I posted should work too as long as the readSubscription is correctly returning the proper data/value.
pellico
