Can't post a float with AIO REST library on ESP8266
by stevesmith on Tue Jan 12, 2016 1:15 pm
Hi. Using all the setup from the ESP8266 example in the Adafruit IO Arduino library, I can post an interger to a feed, but posting a float doesn't work.
This works:
  if (testFeed.send(12)) {
    Serial.println(F("Wrote value to feed"));
  else {
    Serial.println(F("Error writing value to feed!"));
  delay(10000);
But if you change "testFeed.send(12)" to "testFeed.send(12.1)" it throws the error. I'm guessing it's something to do with this in Adafruit_IO_Arduino.cpp (perhaps not working on the ESP8266, where the int version does?):
bool Adafruit_IO_Feed::send(float value) {
    // Convert float to string using scientific notation, then send the value
    // (being careful not to quote it).
    memset(_converted, 0, sizeof(_converted));
    #if defined(ARDUINO_ARCH_AVR)
        // Use avrlibc dtostre function on AVR platforms.
        dtostre(value, _converted, 10, 0);
    #else
        // Otherwise fall back to snprintf on other platforms.
        snprintf(_converted, sizeof(_converted)-1, "%f", value);
    #endif
    return _adapter->send(_name, _converted, _key, false);
Does anyone have anything that's not an ESP8266 that they can test this on? I don't have any other wifi modules. Thanks!
stevesmith
Re: Can't post a float with AIO REST library on ESP8266
by uniontownlabs on Tue Jan 12, 2016 1:20 pm
Which version of the ESP8266 board package are you using? v2.0 from the board manager might fix the issue you are seeing. Check out this GitHub issue for more info: https://github.com/adafruit/io-issues/issues/100
uniontownlabs
by stevesmith on Tue Jan 12, 2016 1:51 pm
Thanks for replying so quickly Todd! I'm using v2.0 from the boards manager. I've just looked at the link you gave me, and so tried it as a generic ESP module instead of a NodeMCU, but that still gives "Error writing value to feed!".
stevesmith
by stevesmith on Tue Jan 12, 2016 3:15 pm
I've found a workaround. Using dtostrf on it and posting the string works :).
stevesmith
by markwal on Thu Jan 14, 2016 2:17 am
I've got the 2.0.0 version of the ESP8266 board package. snprintf(_converted, sizeof(_converted), "%f", value) gives "%f" as the result. And _adapter->send fails.
I'll give the dtostrf workaround a try.
markwal
by markwal on Thu Jan 14, 2016 2:22 am
Looks like several other people have hit this already. There is an issue and a pull request on the Adafruit IO library: https://github.com/adafruit/Adafruit_IO_Arduino/pull/2
markwal
by stevesmith on Thu Jan 14, 2016 1:15 pm
Great, thanks Mark. I'll patch my library with that fix in the meantime.
stevesmith
by Karl33to on Fri Jan 15, 2016 2:17 pm
That patch has been working nicely for me. No more notchy charts, thanks!
Karl33to
by huguescmoi on Wed Feb 03, 2016 3:28 pm
Where is the patch you are talking about ? Still no joy for posting floats...
huguescmoi
by clemens on Wed Feb 03, 2016 4:38 pm
This patch https://github.com/exbarboss/Adafruit_I ... 216dcbabbc
or this workaround viewtopic.php?f=56&t=87611&p=441930#p441189
clemens
