Dashboard issue - Unable to change widgets
by theoriginalrage on Wed Jan 13, 2016 1:15 am
This is how one of my dashboards currently looks. I am unable to resize either widget. When I was first putting this dashboard together and adding widgets they were not showing up, I added about 6 widgets before I noticed a resize arrow in the light grey box above the humidity widget, but that's all that was there. I hovered over it and my cursor turned into a resize cursor so I dragged it out and it was the large Temperature widget that's in the picture. There were 5 more hidden widgets in that box too, because I had made 6 all together. I am unable to resize either of the widgets at this point. I am aware that you have to click the edit dashboard button first and I've done that but to no avail. Is it just me?
Any help or advice would be appreciated.
theoriginalrage
Re: Dashboard issue - Unable to change widgets
by jwcooper on Fri Jan 15, 2016 11:36 am
What browser and version are you using? Are you not able to go into edit mode at all?
jwcooper
by RH3 on Sun Mar 13, 2016 11:37 pm
Did you get a solution to this?
I'm using Internet Explorer and seeing the same issue - sometimes for no obvious reason I can edit and change the blocks and othertimes I can click on the links and nothing happens.
RH.
RH3
