Ethernet
Ethernet
by redder558 on Wed Jan 13, 2016 1:20 am
What boilerplate code do I need to inerface an Arduino ethernet shield with Adafruit I.O. (in arduino language)?
redder558
Re: Ethernet
by jwcooper on Fri Jan 15, 2016 11:37 am
This should get you pretty close:
https://github.com/adafruit/adafruit-io ... ino_cc3000
It's using the cc3k, but swap out the cc3k boilerplate for your ethernet shield setup.
jwcooper
Re: Ethernet
by Philipwith1L on Wed Feb 03, 2016 9:40 pm
Hello there-
I appreciate the link to the repository, JW! I am having problems as well when it comes to the Arduino and Ethernet and actually getting the MQTT to pick up. I don't know if it's because of the variation in chips (W5100, 5200, 5500) or the way that I am hosting the libraries into the Arduino. I just started attempting this today and got no where with it. I really want to use the Adafruit IO but am wondering if I made a bad choice by buying the Seeedstudio shield as my interface.
*Edit- I see that you are the creator of the Learn on this subject. I'll have to give it another through read.
Philipwith1L
Re: Ethernet
by MikeTeachman on Thu Feb 04, 2016 2:06 am
here's the code I use for Arduino ethernet:
viewtopic.php?f=56&t=85393
MikeTeachman
