Possible to have 3 variables in same feed?
by akamediasystem on Fri Jan 15, 2016 4:00 pm
Hi, I'm trying to track 3 axes of accelerometer value in one feed.
I'm able to put a string into a feed, but I'm not clear on how to create a feed that accepts 3 values and not one. Is this possible? Or shall I create 3 feeds, one for each dimension?
FWIW, I was closely reading the learn.adafruit.com guide for several days before I happened to discover the "real" API docs here: http://io.adafruit.com/api/docs/ ...it might be helpful to others to amend the guide to point more obviously to the API docs (and my apologies if I missed some obvious references to them)
AKA
akamediasystem
Re: Possible to have 3 variables in same feed?
by jwcooper on Mon Jan 18, 2016 12:33 pm
You'd want to create a group for this. It's essentially creating three feeds, but will be grouped specific for those 3 feeds. You can name the group, etc.
Docs for groups api here:
http://io.adafruit.com/api/docs/#!/Groups/all
Also, thanks for the suggestion. I bolded the link in the learn guide, but we'll figure out a better way to get folks to the right api docs soon.
jwcooper
by akamediasystem on Mon Jan 18, 2016 1:06 pm
Thanks for the reply - especially on a holiday!
I saw the "Groups" feature in the docs (sorry for not mentioning that), but I didn't realize it applied to my issue - if I "group" my three feeds, can I update them all in one network transaction?
I worked around the issue for now by just shoving a concatenated string into one feed that I'll parse on the client side - but long-term, I'd love to be able to graph/display these three variables on a dashboard...
Thanks again!
AKA
akamediasystem
by jwcooper on Mon Jan 18, 2016 1:22 pm
Yea, you can send them all in a single call to IO.
Send them something like:
 "x": 234,
 "y": 23,
 "z": 11
To /api/groups/#{groupname}/send
jwcooper
by akamediasystem on Mon Jan 18, 2016 2:49 pm
Thanks again for the reply!
Unfortunately I'm still having trouble writing new values to feeds via the Groups POST interface.
The URL I'm POSTing to:
https://io.adafruit.com/api/groups/fixture2/send
The data payload:
"x-fix":149,
"y-fix":117,
"z-fix":252
"x-aio-key":MY_KEY
In response, I get a Success message but the values never update. Here's the full success message:
    "id":33128,
    "name":"fixture2",
    "key":"fixture2",
    "description":null,
    "source":null,
    "properties":null,
    "source_keys":null,
    "created_at":"2016-01-18T18:29:17.413Z",
    "updated_at":"2016-01-18T18:29:36.022Z",
    "feeds":[
        "id":506976,
        "name":"x-fix",
        "key":"x-fix",
        "unit_type":null,
        "unit_symbol":null,
        "mode":null,
        "history":true,
        "last_value":"0.15088623762130737",
        "last_value_at":"2016-01-16T18:58:04.513Z",
        "created_at":"2016-01-16T16:25:14.832Z",
        "updated_at":"2016-01-18T18:29:24.655Z",
        "last_stream":null
        "id":506978,
        "name":"y-fix",
        "key":"y-fix",
        "unit_type":null,
        "unit_symbol":null,
        "mode":null,
        "history":true,
        "last_value":"0.14370118081569672",
        "last_value_at":"2016-01-16T18:58:04.559Z",
        "created_at":"2016-01-16T16:25:28.967Z",
        "updated_at":"2016-01-18T18:29:30.347Z",
        "last_stream":null
        "id":506979,
        "name":"z-fix",
        "key":"z-fix",
        "unit_type":null,
        "unit_symbol":null,
        "mode":null,
        "history":true,
        "last_value":"9.78126049041748",
        "last_value_at":"2016-01-16T18:58:04.506Z",
        "created_at":"2016-01-16T16:25:49.916Z",
        "updated_at":"2016-01-18T18:29:36.026Z",
        "last_stream":null
...I'm not sure what could be wrong - any thoughts or suggestions would be much appreciated!
AKA
akamediasystem
by akamediasystem on Mon Jan 18, 2016 2:59 pm
...after a little more experimentation, it seems that the endpoint /api/groups/{groupname}/send only accepts GET requests and not POST requests...
Leaving this here in case anyone else runs up against this.
Thanks again for the quick holiday-weekend help!
AKA
akamediasystem
by jwcooper on Tue Jan 19, 2016 11:32 am
Interesting, it should accept a POST as well as a GET. Will add it to our list of things to check out.
jwcooper
