Controlling Neopixels from AIO with ESP8266
by archieroques on Mon Jan 18, 2016 4:39 pm
I have just read this tutorial:https://learn.adafruit.com/adafruit-io-basics-neopixel-controller/overview on how to control RGB Neopixels from Adafruit IO. However, this uses the fairly expensive CC3000 board.
Can I do this project with an ESP8266? Will I still need the Arduino, as the ESP8266 is a microcontroller? What changes need to be made? I am looking to use the RGBW Neopixels (PID 2757) - will this still work?
archieroques
Re: Controlling Neopixels from AIO with ESP8266
by jwcooper on Tue Jan 19, 2016 11:30 am
You should be able to do this with just an ESP8266 and the Neopixels. You'll want to likely try the following fork/pull request for the Neopixel library though: https://github.com/adafruit/Adafruit_NeoPixel/pull/58
jwcooper
by archieroques on Thu Jan 21, 2016 3:17 pm
Thank you - that's very helpful.
I'm completely new to using the ESP8266, so is there any tutorials you'd recommend to help me start off with using this with the Neopixels?
archieroques
by meloffbird on Wed Mar 30, 2016 12:48 am
Would love an update to that tutorial! https://learn.adafruit.com/adafruit-io- ... r/overview
meloffbird
