Chart displaying floats as ints
by vkichline on Sat Jan 23, 2016 12:25 am
I have four feeds posting temperatures as floats.
I have a dashboard displaying all four feeds in one line chart. My app had been down for a few days, I changed it today, and now my chart display rounds the floats to ints. If I hover over a datum, it shows the float value, but all deltas snap to full degree increments in the chart.
If I view the feed, I see data like:
73.4 less than 10 seconds ago
...but if I hover over the datum in the chart at the top of the feed display, it shows:
January 22, 2016 08:08 73
I've tried converting the float value to a string with one decimal place (as above) with the same result.
A few days ago I was seeing very fine grain changes in temperature, now I see only large, blocky swings.
All four feeds post once every 30 seconds.
How can I troubleshoot this and display fine-grain charts again?
Thanks for any suggestions. The feeds and dashboard are public, see:
vkichline/feeds/multitemp-t1
vkichline/feeds/multitemp-t2
vkichline/feeds/multitemp-t3
vkichline/feeds/multitemp-t4
vkichline/multitemp
vkichline
Re: Chart displaying floats as ints
by vkichline on Sat Jan 23, 2016 12:44 am
The error appears to be mine.
Using a finer vertical scale, I see the chart is displaying the data accurately. For some reason the deltas being published is chunkier than before.
Tip: if your deltas look rounded, set the vertical axis to a very small value to verify accuracy, or examine your data more carefully than I did.
Sorry my first post was a misdirect.
vkichline
