Posting DHT22 in Fahrenheit
by jupiter457 on Mon Jan 25, 2016 6:35 pm
I apologize in advance for this question, I'm very new to all of this. I am following the Sensor Module example from the Home Automation in the Cloud tutorial from Adafruit Learn. I seem to have everything up and running but I would like to post my temperatures in Fahrenheit and not Celsius. Could you tell me how I would need to modify the sample code to do that?
Thank you very much
Huzzah.txt
(4.51 KiB) Downloaded 175 times
jupiter457
Re: Posting DHT22 in Fahrenheit
by jupiter457 on Mon Jan 25, 2016 7:57 pm
I should have been more clear. I understand how to mathematically do the conversion, I don't understand how to get the sketch to do this and then post it. Do I need to create a new variable called Fahrenheit and tell the Huzzah to post that to Adafruit.io instead of readTemperature?
I see that the code has:
// Grab the current state of the sensor
int humidity_data = (int)dht.readHumidity();
int temperature_data = (int)dht.readTemperature();
// Publish data
if (! temperature.publish(temperature_data))
Serial.println(F("Failed to publish temperature"));
else
Serial.println(F("Temperature published!"));
jupiter457
by jupiter457 on Tue Jan 26, 2016 11:02 am
Ahh, that's exactly what I needed. Thank you very much.
jupiter457
by Luminaric on Wed Jan 27, 2016 5:10 pm
Jupiter,
In the DHT library I use this code:
float tempF = dht.readTemperature(true);
Hope that's what you were looking for. BTW, it is also in the example sketch.
Luminaric
