Help editing Python to integrate with IO
by dpowrie on Wed Jan 27, 2016 8:27 am
Hi All,
Very new, and spent many hours trying to figure this out, so apologies if the answer is out there...
I'm trying to set up a Raspberry Pi to measure temperature, motion (with a PIR) and turn on a camera when triggered.
I've currently been able to get the temperature up and running with https://learn.adafruit.com/dht-humidity ... ll-updated
But it would seem that the Adafruit IO platform would be a better way to do this as with time and experience I could add the other elements I'm after.
It seems from the tutorials that it simply involves adding a few lines of code to a basic measurement python script, but being so new I'm not sure exactly how to do it.
Any chance someone can point me to a demonstration of python before and after integration with Adafuit IO?
I figure if I can get the temperature logging going, the rest should be much easier!
Thanks in advance,
DP
dpowrie
Re: Help editing Python to integrate with IO
by jwcooper on Fri Jan 29, 2016 2:16 pm
Here is a python example. You should be able to just drop this in after installing the python library:
https://github.com/adafruit/io-client-p ... /simple.py
Then just send your temp/motion/camera values to a feed for each one.
Install info here:
https://github.com/adafruit/io-client-python
jwcooper
by dpowrie on Wed Feb 03, 2016 7:57 am
Thanks JW,
Chipped away at it, but I think I need to go away and learn more Python!
Cheers,
DP
dpowrie
by tdack on Thu Feb 04, 2016 6:50 am
A really simple python example:
import paho.mqtt.publish as publish
msgs =[{'topic': "some_user/feeds/temperature", 'payload': 27, 'retain': false},
       {'topic': "some_user/feeds/motion", 'payload': "Yes!", 'retain': false}]
publish.multiple(msgs,
                 hostname="io.adafruit.com",
                 port="1883",
                 auth={'username': "some_user", 'password': "aio key"})
That will publish to two feeds on io.adafruit,com - temperature and motion
tdack
by dpowrie on Thu Feb 04, 2016 11:34 pm
Thanks again to the forum. Will try when I get a chance.
dpowrie
