Adafruit IO connectivity problems
by Riseley on Wed Jan 27, 2016 11:49 pm
I am a newbie and am trying to set an internet of things dashboard with a light sensor per the instructions on your website and seem to be having connection problems as outlined below:
Hello, CC3000!MAC Address : 0x70 0xFF 0x76 0x02 0xE9 0x7D
Deleting old connection profiles
Attempting to connect to NETGEAR11
Hello, CC3000!
Initialising the CC3000 ...
Firmware V. : 1.24
Connected!
Request DHCP
IP Addr: 10.0.0.14
Netmask: 255.255.255.0
Gateway: 10.0.0.1
DHCPsrv: 10.0.0.1
DNSserv: 10.0.0.1
AIO connect failed
AIO connection dropped. Attempting reconnectAIO connect failed
I am using Uno 1.6.5 and have successfully executed the following sketches: buildtest, WebClient, ntp Test, GeoLocation,
My sketch is outlined below:
// Required libraries
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <PubSubClient.h>
// Light level sensor
#define LIGHT_SENSOR_PIN A0
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// Create CC3000 instance
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT, SPI_CLOCK_DIVIDER);
// WiFi network name & password
#define WLAN_SSID "NETGEAR11"
#define WLAN_PASS "XXXXXXX"
#define WLAN_SECURITY WLAN_SEC_WPA2
// Username & AIO key
#define ADAFRUIT_USERNAME "XXXXX"
#define AIO_KEY "My key"
// Path for sensors
#define LIGHT_PUBLISH_PATH "api/feeds/light/data/send.json"
// CC3000 client & MQTT client instances
Adafruit_CC3000_Client client = Adafruit_CC3000_Client();
PubSubClient mqttclient("io.adafruit.com", 1883, callback, client);
// Callback
void callback (char* topic, byte* payload, unsigned int length) {
Serial.println(topic);
Serial.write(payload, length);
Serial.println("");
void setup(void)
Serial.begin(115200);
Serial.println(F("Hello, CC3000!\n"));
Serial.println(F("\nInitialising the CC3000 ..."));
if (!cc3000.begin()) {
Serial.println(F("Unable to initialise the CC3000! Check your wiring?"));
for(;;);
uint16_t firmware = checkFirmwareVersion();
if (firmware < 0x113) {
Serial.println(F("Wrong firmware version!"));
for(;;);
displayMACAddress();
Serial.println(F("\nDeleting old connection profiles"));
if (!cc3000.deleteProfiles()) {
Serial.println(F("Failed!"));
while(1);
/* Attempt to connect to an access point */
char *ssid = WLAN_SSID; /* Max 32 chars */
Serial.print(F("\nAttempting to connect to ")); Serial.println(ssid);
/* NOTE: Secure connections are not available in 'Tiny' mode! */
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
while(1);
Serial.println(F("Connected!"));
/* Wait for DHCP to complete */
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP()) {
delay(100); // ToDo: Insert a DHCP timeout!
/* Display the IP address DNS, Gateway, etc. */
while (!displayConnectionDetails()) {
delay(1000);
// Connect to AIO
mqtt_connect();
void loop(void) {
// Reconnect if we lost connection to AIO
if(! mqttclient.connected()) {
Serial.print(F("AIO connection dropped. Attempting reconnect"));
mqtt_connect();
// Measure ambient light
float light_level_reading = analogRead(LIGHT_SENSOR_PIN);
int light_level = (int)(light_level_reading/1024.*100.);
// Publish data on Adafruit.io
mqttclient.publish(LIGHT_PUBLISH_PATH, (char *) String(light_level).c_str());
delay(2000);
// Keep connection to MQTT broker
mqttclient.loop();
@brief Tries to read the CC3000's internal firmware patch ID
uint16_t checkFirmwareVersion(void)
uint8_t major, minor;
uint16_t version;
#ifndef CC3000_TINY_DRIVER
if(!cc3000.getFirmwareVersion(&major, &minor))
Serial.println(F("Unable to retrieve the firmware version!\r\n"));
version = 0;
else
Serial.print(F("Firmware V. : "));
Serial.print(major); Serial.print(F(".")); Serial.println(minor);
version = major; version <<= 8; version |= minor;
#endif
return version;
@brief Tries to read the 6-byte MAC address of the CC3000 module
void displayMACAddress(void)
uint8_t macAddress[6];
if(!cc3000.getMacAddress(macAddress))
Serial.println(F("Unable to retrieve MAC Address!\r\n"));
else
Serial.print(F("MAC Address : "));
cc3000.printHex((byte*)&macAddress, 6);
@brief Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
Serial.println(F("Unable to retrieve the IP Address!\r\n"));
return false;
else
Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
Serial.println();
return true;
void mqtt_connect() {
char client_name[30];
// generate new client name
sprintf(client_name, "adafruit-cc3000-%ul", micros());
// attempt connection
if (mqttclient.connect(client_name, AIO_KEY, NULL)) {
Serial.println(F("Connected to AIO"));
} else {
Serial.println(F("AIO connect failed"));
Any advice will be much appreciated.
Riseley
Re: Adafruit IO connectivity problems
by thermalhound on Mon Feb 01, 2016 7:19 am
Hi there.
Not sure I can be of much help, I'm having problems connecting to AIO myself, however I did notice that you have gone a slightly different route to me that I am now going to try.
I am using the adafruit mqtt library to connect but am going to swap over to the pubsub client that you have used.
When looking at your code I noticed that you have called
It may be worth trying something along the lines of
mqttclient.connect(client_name, ADAFRUIT_USERNAME, AIO_KEY)
If I have any success with this I'll post my code up later
thermalhound
by adamp2 on Fri Feb 26, 2016 1:26 am
Yes, I am having the same problem.
Has anyone been successful with this sketch?
Serial Monitor:
Hello, CC3000!
Firmware V. : 1.24
MAC Address : 0x08 0x00 0x28 0x57 0x9A 0x2D
Attempting to connect to My Network
Connected!
Request DHCP
IP Addr: 192.168.0.104
Gateway: 192.168.0.1
DHCPsrv: 192.168.0.1
DNSserv: 192.168.0.1
AIO connect failed
The Sketch:
adafruit_io_sensors
// DHT sensor
#define DHTPIN 7 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22
DHT dht(DHTPIN, DHTTYPE);
#define LIGHT_SENSOR_PIN A0 //might need to change name to AMBIENT_LIGHT_SENSOR_PIN A0
#define WLAN_SSID "My Network"
#define WLAN_PASS "**************"
#define ADAFRUIT_USERNAME "My Username"
#define AIO_KEY "My Key"
// Path for sensors
#define AIR_TEMPERATURE_PUBLISH_PATH "api/feeds/air_temperature/data/send.json" //made change to reflect path designated in dashboard
#define HUMIDITY_PUBLISH_PATH "api/feeds/humidity/data/send.json"
#define AMBIENT_LIGHT_SENSOR_PUBLISH_PATH "api/feeds/ambient_light_sensor/data/send.json" //made change to reflect path designated in dashboard
// Callback
Serial.println("");
void setup(void)
// Init DHT sensor
dht.begin();
for(;;);
for(;;);
while(1);
while(1);
delay(1000);
// Connect to AIO
mqtt_connect();
void loop(void) {
mqtt_connect();
// Measure temperature & humidity
int h = dht.readHumidity();
int t = dht.readTemperature();
mqttclient.publish(AIR_TEMPERATURE_PUBLISH_PATH, (char *) String(t).c_str()); //made change to reflect path designated in dashboard
delay(2000);
mqttclient.publish(HUMIDITY_PUBLISH_PATH, (char *) String(h).c_str());
delay(2000);
mqttclient.publish(AMBIENT_LIGHT_SENSOR_PUBLISH_PATH, (char *) String(light_level).c_str()); //made change to reflect path designated in dashboard
delay(2000);
mqttclient.loop();
uint16_t version;
version = 0;
else
#endif
return version;
else
return false;
else
Serial.println();
return true;
} else {
adamp2
