Single Command Line Argument to Adafruit IO
by NFarrow on Thu Jan 28, 2016 2:17 am
I thought that the Adafruit IO team might think this is cool. I am running this code on a Raspberry Pi 2. python 2.7
This is how I post data to the Adafruit IO feed. (./FeedPostAdaFruitIO.py 123)
https://github.com/VeggieVampire/AdaFruitIO/blob/master/FeedPostAdaFruitIO.py
Also this is how I read feed data from Adafruit IO.
https://github.com/VeggieVampire/AdaFruitIO/blob/master/ReadAdaFruitIO.py
I do have a small issue when I go check the feed values I see, '123' ticks on the data. Would any Python gurus know how to clean the string? Also note I have tried urllib but with no luck.....
Nick Farrow
Example usage:
So if I wanted to get NOAA's weather station and submit the data to AIO feed, I could do something like this. station KTUL
./FeedPostAdaFruitIO.py $(curl -sS "http://w1.weather.gov/xml/current_obs/display.php?stid=KTUL"|sed -n  '32p'|awk '{print $1$2$3$4$5$6}'|awk -F'[<|>]' '{print $3}'|rev | cut -c 8- | rev)
NFarrow
