.NET sample code to use with Adafruit.io
Nikolai1024
Post by Nikolai1024 »
Is there any sample code for .NET to connect to adafruilt.io? I'm trying to integrate existing vb.net app with physical dashboard I'm building.
Nick
jwcooper
Re: .NET sample code to use with Adafruit.io
Post by jwcooper »
Not that I'm aware of. You may want to just use a rest client and follow along with the docs: https://io.adafruit.com/api/docs
MQTT should work very similarly to our other MQTT tutorials if there is a .NET MQTT client that you can use.
Return to “Internet of Things: Adafruit IO and Wippersnapper”
