Black Lives Matter - Action and Equality. ... Adafruit is part of the Stop Hate for Profit campaign. Adafruit is open and shipping.
Rest api format conversion missing data
by gatorson on Fri Jan 29, 2016 4:56 pm
I am successfully able to "get" data using the rest api. However when i change the format to xml from the default json my latitude and longitude no longer come thru.
Json has full data:
"id":119180387,
"value":"0",
"position":null,
"lat":26.094135,
"lon":-80.254913,
"ele":-13.5,
"feed_id":511148,
"group_id":null,
"expiration":null,
"completed_at":"2016-01-29T20:54:51.452Z",
"created_at":"2016-01-29T18:17:29.951Z",
"updated_at":"2016-01-29T20:54:51.452Z",
"created_epoch":1454091449.95177
Xml missing data
Response content:
<?xml version="1.0" encoding="UTF-8"?>
<stream>
<id type="integer">119181203</id>
<value>0</value>
<position type="integer" nil="true"/>
<expiration type="dateTime" nil="true"/>
<feed-id type="integer">511148</feed-id>
<created-at type="dateTime">2016-01-29T18:17:55Z</created-at>
<updated-at type="dateTime">2016-01-29T20:55:31Z</updated-at>
<completed-at type="dateTime">2016-01-29T20:55:31Z</completed-at>
<location-id type="integer">53241</location-id>
<group-id type="integer" nil="true"/>
</stream>
gatorson
Re: Rest api format conversion missing data
by jwcooper on Mon Feb 08, 2016 6:44 pm
Looks like a bug. I'll create an issue in our tracker. Thank you!
jwcooper
