Rest api format conversion missing data
by gatorson on Fri Jan 29, 2016 4:56 pm
I am successfully able to "get" data using the rest api. However when i change the format to xml from the default json my latitude and longitude no longer come thru.
Json has full data:
"id":119180387,
"value":"0",
"position":null,
"lat":26.094135,
"lon":-80.254913,
"ele":-13.5,
"feed_id":511148,
"group_id":null,
"expiration":null,
"completed_at":"2016-01-29T20:54:51.452Z",
"created_at":"2016-01-29T18:17:29.951Z",
"updated_at":"2016-01-29T20:54:51.452Z",
"created_epoch":1454091449.95177
Xml missing data
Response content:
<?xml version="1.0" encoding="UTF-8"?>
<stream>
<id type="integer">119181203</id>
<value>0</value>
<position type="integer" nil="true"/>
<expiration type="dateTime" nil="true"/>
<feed-id type="integer">511148</feed-id>
<created-at type="dateTime">2016-01-29T18:17:55Z</created-at>
<updated-at type="dateTime">2016-01-29T20:55:31Z</updated-at>
<completed-at type="dateTime">2016-01-29T20:55:31Z</completed-at>
<location-id type="integer">53241</location-id>
<group-id type="integer" nil="true"/>
</stream>
gatorson
Re: Rest api format conversion missing data
by jwcooper on Mon Feb 08, 2016 6:44 pm
Looks like a bug. I'll create an issue in our tracker. Thank you!
jwcooper
