Virtual Toggle
Virtual Toggle
by redder558 on Sat Jan 30, 2016 1:50 am
How would I use a virtual Toggle to control an LED on my Arduino Ethernet shield?
I have this code so far from the included example:
  Adafruit MQTT Library Ethernet Example
  products from Adafruit!
  Written by Alec Moore
  Derived from the code written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
#include <SPI.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#include <Ethernet.h>
#include <EthernetClient.h>
#include <Dns.h>
#include <Dhcp.h>
/************************* Ethernet Client Setup *****************************/
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
//Uncomment the following, and set to a valid ip if you don't have dhcp available.
//IPAddress iotIP (192, 168, 0, 42);
//Uncomment the following, and set to your preference if you don't have automatic dns.
//IPAddress dnsIP (8, 8, 8, 8);
//If you uncommented either of the above lines, make sure to change "Ethernet.begin(mac)" to "Ethernet.begin(mac, iotIP)" or "Ethernet.begin(mac, iotIP, dnsIP)"
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    "redder558"
#define AIO_KEY         "e03285de4a3272dccbe32839dcef8218866f85f6"
/************ Global State (you don't need to change this!) ******************/
//Set up the ethernet client
EthernetClient client;
// Store the MQTT server, client ID, username, and password in flash memory.
// This is required for using the Adafruit MQTT library.
const char MQTT_SERVER[] PROGMEM    = AIO_SERVER;
// Set a unique MQTT client ID using the AIO key + the date and time the sketch
// was compiled (so this should be unique across multiple devices for a user,
// alternatively you can manually set this to a GUID or other random value).
const char MQTT_CLIENTID[] PROGMEM  = __TIME__ AIO_USERNAME;
const char MQTT_USERNAME[] PROGMEM  = AIO_USERNAME;
const char MQTT_PASSWORD[] PROGMEM  = AIO_KEY;
Adafruit_MQTT_Client mqtt(&client, MQTT_SERVER, AIO_SERVERPORT, MQTT_CLIENTID, MQTT_USERNAME, MQTT_PASSWORD);
// You don't need to change anything below this line!
#define halt(s) { Serial.println(F( s )); while(1);  }
/****************************** Feeds ***************************************/
// Setup a feed called 'onoff' for subscribing to changes.
const char ONOFF_FEED[] PROGMEM = AIO_USERNAME "/feeds/onoff";
Adafruit_MQTT_Subscribe onoffbutton = Adafruit_MQTT_Subscribe(&mqtt, ONOFF_FEED);
/*************************** Sketch Code ************************************/
int pin = 13;
  Serial.begin(115200);
  Serial.println(F("Adafruit MQTT demo"));
  // Initialise the Client
  Serial.print(F("\nInit the Client..."));
  Ethernet.begin(mac);
  delay(1000); //give the ethernet a second to initialize
  pinMode(pin,OUTPUT);
  mqtt.subscribe(&onoffbutton);
uint32_t x=0;
  // Ensure the connection to the MQTT server is alive (this will make the first
  // connection and automatically reconnect when disconnected).  See the MQTT_connect
  // function definition further below.
  MQTT_connect();
  // this is our 'wait for incoming subscription packets' busy subloop
  Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(1000))) {
    if (subscription == &onoffbutton) {
      Serial.print(F("Got: "));
      Serial.println((char *)onoffbutton.lastread);
      if (onoffbutton.lastread == "ON") {
        digitalWrite(pin,HIGH);
  // ping the server to keep the mqtt connection alive
  if(! mqtt.ping()) {
    mqtt.disconnect();
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
       Serial.println(mqtt.connectErrorString(ret));
       Serial.println("Retrying MQTT connection in 5 seconds...");
       mqtt.disconnect();
       delay(5000);  // wait 5 seconds
  Serial.println("MQTT Connected!");
However, the Arduino IDE says
comparison between distinct pointer types 'uint8_t* {aka unsigned char*}' and 'const char*' lacks a cast [-fpermissive]. I don't know how to read what the value is on a virtual toggle in adafruit.io.
redder558
Re: Virtual Toggle
by theoriginalrage on Tue Feb 02, 2016 1:02 am
This is exactly what I was attempting to do right now, but I didn't have any code, or idea, of where to start.
Where did you get the code you referenced?
theoriginalrage
Re: Virtual Toggle
by redder558 on Tue Feb 02, 2016 1:32 am
theoriginalrage wrote:This is exactly what I was attempting to do right now, but I didn't have any code, or idea, of where to start.
I used the MQTT library's example code, and found the part about the onoff feed. I then modified it to how I thought it would work (which didn't).
redder558
