MQTT connection fails when subscribing to 4 topics
by thermalhound on Sun Jan 31, 2016 8:04 pm
Hi all,
I'm having a bit of a problem with a sketch and I can't for the life of me work out why.
I am trying to subscribe to 4 feeds (onoff, red-led, green-led, blue-led) I have set up in my account. I can subscribe to up to 3 of them at any one time and the data comes through no problem. As soon as I add the 4th subscription MQTT refuses to connect.
Hardware ... Mac OSx 10.10, Arduino IDE 1.6.5, ESP12-E module
Code ... Included below. It's basically a replica of the (excellent!) 2subs code included as an example but with 2 extra subscriptions added in.
Hopefully it's something stupid I'm over looking but any feedback from a fresh pair of eyes would be greatly appreciated.
  Adafruit MQTT Library ESP8266 Example
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
// the on off button feed turns this LED on/off
#define LED 2
// the slider feed sets the PWM output of this pin
#define redLed 15
#define greenLed 12
#define blueLed 13
/************************* WiFi Access Point *********************************/
#define WLAN_SSID       "MySSID"
#define WLAN_PASS       "MyPassword"
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883                   // use 8883 for SSL
#define AIO_USERNAME    "MyUsername"
#define AIO_KEY         "MyAIO_Key"
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
const char MQTT_SERVER[] PROGMEM    = AIO_SERVER;
const char MQTT_USERNAME[] PROGMEM  = AIO_USERNAME;
const char MQTT_PASSWORD[] PROGMEM  = AIO_KEY;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, MQTT_SERVER, AIO_SERVERPORT, MQTT_USERNAME, MQTT_PASSWORD);
/****************************** Feeds ***************************************/
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
// Setup a feed called 'onoff' for subscribing to changes.
//const char ONOFF_FEED[] PROGMEM = AIO_USERNAME "/feeds/onoff";
Adafruit_MQTT_Subscribe onoffbutton = Adafruit_MQTT_Subscribe(&mqtt, "thermalhound/feeds/onoff");
//const char RED_SLIDER_FEED[] PROGMEM = AIO_USERNAME "/feeds/red-led";
Adafruit_MQTT_Subscribe redSlider = Adafruit_MQTT_Subscribe(&mqtt, "thermalhound/feeds/red-led");
//const char GREEN_SLIDER_FEED[] PROGMEM = AIO_USERNAME "/feeds/green-led";
Adafruit_MQTT_Subscribe greenSlider = Adafruit_MQTT_Subscribe(&mqtt, "thermalhound/feeds/green-led");
//const char BLUE_SLIDER_FEED[] PROGMEM = AIO_USERNAME "/feeds/blue-led";
Adafruit_MQTT_Subscribe blueSlider = Adafruit_MQTT_Subscribe(&mqtt, "thermalhound/feeds/blue-led");
/*************************** Sketch Code ************************************/
// Bug workaround for Arduino 1.6.6, it seems to need a function declaration
// for some reason (only affects ESP8266, likely an arduino-builder bug).
void MQTT_connect();
  pinMode(LED, OUTPUT);
  pinMode(redLed, OUTPUT);
  pinMode(greenLed, OUTPUT);
  pinMode(blueLed, OUTPUT);
  Serial.begin(115200);
  delay(10);
  Serial.println(F("Adafruit MQTT demo"));
  // Connect to WiFi access point.
  Serial.println(); Serial.println();
  Serial.print("Connecting to ");
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println();
  Serial.println("WiFi connected");
  Serial.println("IP address: "); Serial.println(WiFi.localIP());
  //MQTT_connect();
  // Setup MQTT subscription for onoff & slider feed.
  mqtt.subscribe(&onoffbutton);
  mqtt.subscribe(&redSlider);
  mqtt.subscribe(&greenSlider);
  mqtt.subscribe(&blueSlider);
uint32_t x=0;
  // Ensure the connection to the MQTT server is alive (this will make the first
  // connection and automatically reconnect when disconnected).  See the MQTT_connect
  // function definition further below.
  MQTT_connect();
  // this is our 'wait for incoming subscription packets' busy subloop
  // try to spend your time here
  Serial.println("loop");
  Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(5000))) {
    // Check if its the onoff button feed
    if (subscription == &onoffbutton) {
      Serial.print(F("On-Off button: "));
      Serial.println((char *)onoffbutton.lastread);
      if (strcmp((char *)onoffbutton.lastread, "ON") == 0) {
        digitalWrite(LED, LOW);
      if (strcmp((char *)onoffbutton.lastread, "OFF") == 0) {
        digitalWrite(LED, HIGH);
    // check if its the red slider feed
    if (subscription == &redSlider) {
      Serial.print(F("Red Slider: "));
      Serial.println((char *)redSlider.lastread);
      uint16_t sliderval = atoi((char *)redSlider.lastread);  // convert to a number
      analogWrite(redLed, sliderval);
    // check if its the green slider feed
    if (subscription == &greenSlider) {
      Serial.print(F("Green Slider: "));
      Serial.println((char *)greenSlider.lastread);
      uint16_t sliderval = atoi((char *)greenSlider.lastread);  // convert to a number
      analogWrite(greenLed, sliderval);
    // check if its the blue slider feed
    if (subscription == &blueSlider) {
      Serial.print(F("Blue Slider: "));
      Serial.println((char *)blueSlider.lastread);
      uint16_t sliderval = atoi((char *)blueSlider.lastread);  // convert to a number
      analogWrite(blueLed, sliderval);
  // ping the server to keep the mqtt connection alive
  if(! mqtt.ping()) {
    mqtt.disconnect();
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  uint8_t retries = 10;
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
       Serial.println(mqtt.connectErrorString(ret));
       Serial.println("Retrying MQTT connection in 5 seconds...");
       mqtt.disconnect();
       delay(5000);  // wait 5 seconds
       retries--;
       if (retries == 0) {
         // basically die and wait for WDT to reset me
         while (1);
  Serial.println("MQTT Connected!");
thermalhound
