[SOLVED] Error writing value to feed
by huguescmoi on Tue Feb 02, 2016 4:30 pm
Just starting with the Adafruit IO ESP8266 Arduino example. I use the example sketch, without any modifications (except my own ssid, password, AIO key and feed name. I do not succeed to write any values to the feed.
My feed that I created to test has the following parameters:
key: poules-temperature
Running the script gives this ouput on serial monitor:
Adafruit IO ESP8266 test!
Connecting to (masked)
WiFi connected
IP address:
192.168.1.30
Ready!
Error writing value to feed!
Waiting 10 seconds and then reading the feed value.
Received value from feed:
Waiting 10 seconds and then writing a new feed value.
The script I run is (with ssid/password masked):
// Adafruit IO REST API access with ESP8266
// For use with ESP8266 Arduino from:
// https://github.com/esp8266/Arduino
// Works great with ESP8266 modules like the Adafruit Huzzah ESP:
// ----> https://www.adafruit.com/product/2471
// Written by Tony DiCola for Adafruit Industries.
// MIT license, all text above must be included in any redistribution.
#include <ESP8266WiFi.h>
#include "Adafruit_IO_Client.h"
// Configure WiFi access point details.
#define WLAN_SSID "***"
#define WLAN_PASS "***"
// Configure Adafruit IO access.
#define AIO_KEY "***"
// Create an ESP8266 WiFiClient class to connect to the AIO server.
WiFiClient client;
Adafruit_IO_Client aio = Adafruit_IO_Client(client, AIO_KEY);
Adafruit_IO_Feed testFeed = aio.getFeed("poules","poules-temperature");
// Global state to increment a number and send it to the feed.
unsigned int count = 0;
// Setup serial port access.
Serial.begin(115200);
delay(10);
Serial.println(); Serial.println();
Serial.println(F("Adafruit IO ESP8266 test!"));
// Connect to WiFi access point.
Serial.print("Connecting to ");
Serial.println(WLAN_SSID);
WiFi.begin(WLAN_SSID, WLAN_PASS);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println();
Serial.println("WiFi connected");
Serial.println("IP address: "); Serial.println(WiFi.localIP());
// Initialize the Adafruit IO client class (not strictly necessary with the
// client class, but good practice).
aio.begin();
Serial.println(F("Ready!"));
// Increment the count value and write it to the feed.
count += 1;
// To write a value just call the feed's send function and pass it the value.
// Send will create the feed on Adafruit IO if it doesn't already exist and
// then add the value to it. Send returns a boolean that's true if it works
// and false if it fails for some reason.
if (testFeed.send(count)) {
Serial.print(F("Wrote value to feed: ")); Serial.println(count, DEC);
else {
Serial.println(F("Error writing value to feed!"));
// Now wait 10 seconds and read the current feed value.
Serial.println(F("Waiting 10 seconds and then reading the feed value."));
delay(10000);
// To read the latest feed value call the receive function on the feed.
// The returned object will be a FeedData instance and you can check if it's
// valid (i.e. was successfully read) by calling isValid(), and then get the
// value either as a text value, or converted to an int, float, etc.
FeedData latest = testFeed.receive();
if (latest.isValid()) {
Serial.print(F("Received value from feed: ")); Serial.println(latest);
// By default the received feed data item has a string value, however you
// can use the following functions to attempt to convert it to a numeric
// value like an int or float. Each function returns a boolean that indicates
// if the conversion succeeded, and takes as a parameter by reference the
// output value.
int i;
if (latest.intValue(&i)) {
Serial.print(F("Value as an int: ")); Serial.println(i, DEC);
// Other functions that you can use include:
// latest.uintValue() (unsigned int)
// latest.longValue() (long)
// latest.ulongValue() (unsigned long)
// latest.floatValue() (float)
// latest.doubleValue() (double)
else {
Serial.print(F("Failed to receive the latest feed value!"));
// Now wait 10 more seconds and repeat.
Serial.println(F("Waiting 10 seconds and then writing a new feed value."));
delay(10000);
What do i do wrong ? HELLP
huguescmoi
Re: Error writing value to feed
by huguescmoi on Wed Feb 03, 2016 2:14 pm
For memory and help others, the mistake was due to the fact that Adafruit IO does not support spaces in the name of a feed.
Should be written in BOLD LETTERS in the tutorial to avoid loosing hours of troubleshooting for something we can't make up without documentation.
huguescmoi
