How to post a float value to a feed ?
by huguescmoi on Wed Feb 03, 2016 2:17 pm
Context : ESP8266 Arduino, posting sensor data to a feed.
Issue : I succeed to post int values to a feed (with command MyTestFeed.send(x), x being an integer); but as soon as I try to execute the same command with x being a float, it fails to write x to the feed.
Can we only post interger to Adafruit IO ? If not, what do I have to change to post a number (a float) like "21.35" ?
huguescmoi
Re: How to post a float value to a feed ?
by clemens on Wed Feb 03, 2016 3:12 pm
clemens
by huguescmoi on Wed Feb 03, 2016 3:31 pm
I do not see any solution in this other forum topic you are pointing to, only confirmation of the problem. Concretely what and where is the patch they are mentionning ?
huguescmoi
by clemens on Wed Feb 03, 2016 4:31 pm
viewtopic.php?f=56&t=87611&p=441930#p441189
I've found a workaround. Using dtostrf on it and posting the string works :).
clemens
by huguescmoi on Thu Feb 04, 2016 5:36 am
Thx.
However this command converts a float into a string. Isn't that a problem for IO Adafruit to draw charts requiring number values and not strings ? It does not seem very logical...
huguescmoi
by clemens on Thu Feb 04, 2016 8:43 am
In my setup it is working well, and the string / char definition is on the Arduino side only. So the Adafruit IO gets only some json or whatever stuff and no information that the variable is a char!
Nevertheless yes, that's a bit funny but not so unique. It's necessary for some other payloads also, e.g. the RFM69 lib expects also char as payload.
clemens
